Nov 13, 2023 12:34 PM UTC
build associated part, however, in an assembly BOM, the same part is showing as unassociated
Initially posted in this topic
i am hoping you can help me, i am able to build associated part and view it on a single level as build when comparing to the part structure, however, in an assembly BOM, the same part is showing as unassociated. Is there a step i am missing?
AnthonyCAnswer
Nov 23, 2023 7:23 AM UTC
the set up was not done correctly from our system and was fixed by the admin from the provider. thanks everyone for contributing.
Nov 14, 2023 6:33 AM UTC
Hi Antony,
Please check when you compare the WT Part Structure & CAD Structure both versions are the same. If it's not apply the "Set for build".
For your more information: https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/WorkingWithCADandPartStructures/TDDBuild.html
Amir
AnthonyC12-AmethystAuthor
Nov 17, 2023 10:08 AM UTC
i made a seperate post to try solve this.
https://community.ptc.com/t5/Windchill/CAD-Doc-vs-Part-BOM-sub-assemblies-not-rebuilding/m-p/912748#M75992
i am unable to set for build from the menu. so far, it seems our windchill/ creo configs are not running correctly. my versions are matching correctly,
