Connect existing Windchill setup to Active Directory
  • October 9, 2014
  • 2 replies
  • 1841 views
Where can i find documentation on how to connect and existing Windchill 10.1 installation to our Active Directory?
Thank you,
Glen
Best answer by AntonBagryanov
Hello. You should looking at the info*Engine administration.
Go to the Site/Utilities/Info*Engine Administration. Then log in to the Info*Engine admin tool (login is cn=Manager). Then click on the com.yourorg.EnterpriseLdap link and there you should add all properties for your LDAP connection.
As to your specific question about documentation, I got a list of CS documents by putting in a case. It is possible to find them yourself by searching "Active Directory" and "JNDI" or "Info*Engine" but here are the ones I've referenced.
CS24211
CS29445
CS29454
CS37358
