Creo View 2.0 Question
  • September 11, 2013
  • 937 views
When creating an annotation in Creo View, using the Markup Tab, I wonder if there is a setting to change how the selection and de-selection works. Current functionality is that if I am adding multiple freehand lines to a drawing, I select freehand and draw my line. I then need to go back up to the freehand icon and click it again to create another line. Is there a way to set the system so I can create multiple lines, without having to go back to the ribbon all the time? Note: this is the same for Notes, Leader lines, and Shapes.
Windchill 10.0 M040
Creo View Lite 2.0 M040 build 15
23-Emerald II
September 27, 2013
Looks like you figured out that this isn't possible OOTB and opened an Idea for this: http://communities.ptc.com/ideas/3197
