Getting Version of EPMDocument (Iteration,revision) in database
  • October 21, 2014
  • 3 replies
  • 2444 views
Dear community,
i need to find out the version (iteratio, revision) of a epm document in a sql query. Does anyone know, how iteration and revision are connected to empdocument table in the windchill database?
Any help is appreciated.
Thanks.
Best answer by BenPerry
Revision is VERSIONIDA2VERSIONINFO
Iteration is ITERATIONIDA2ITERATIONINFO
Therefore
select VERSIONIDA2VERSIONINFO || '.' || ITERATIONIDA2ITERATIONINFO
will return you something like "A.1" (revision.iteration) if you're interested in including the . in the result.
Here is a sample query to get the filename in VAULTS of a EPMDoc
select
mas.cadname cadname,
doc.VERSIONIDA2VERSIONINFO || NVL2(doc.oneOffVersionIdA2oneOffVersi ,'-' || doc.oneOffVersionIdA2oneOffVersi,'') || '.' || doc.ITERATIONIDA2ITERATIONINFO ver,
ad.modifystampa2 modified,
ad.role role,
M.path,
to_char(fi.uniquesequencenumber,'0000000000000x') vault_filename,
ad.filename,
m.status,
ad.filesize filesize_bytes
from
holdertocontent hc,
applicationdata ad,
fvitem fi,
EPMDocument doc,
EPMDocumentmaster mas,
FVMOUNT M
where
hc.ida3b5 = ad.ida2a2
and ad.ida3a5 = fi.ida2a2
and hc.ida3a5=doc.ida2a2
AND Fi.ida3a4= m.ida3a5
--and ad.role='THUMBNAIL'
and doc.ida3masterreference=mas.ida2a2
--and mas.cadname in ('cadfile1.prt','cadfile1.drw')
and mas.cadname like 'cadfile%.prt'
order by
mas.cadname,
ver,
role
MarcoTosin
Stefan take a look at this article from Technical Support https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS131357&lang=en
If it's not mandatory for you to have your result through an sql query, you can read also this article I wrote here http://communities.ptc.com/docs/DOC-6348 where you can find a lot of things about reporting.
Maybe you can also subscribe to this group http://communities.ptc.com/groups/reporting and vote this two idea http://communities.ptc.com/ideas/4634 and http://communities.ptc.com/ideas/4659
Because of an error in the way link works on Community, you have to delete, in your browser, the part from left until "/" before http, to read the ideas.
Marco
Marco
BenPerry
BenPerry15-MoonstoneAnswer
Therefore
select
ad.role role,
M.path,
ad.filename,
m.status,
from
holdertocontent hc,
applicationdata ad,
fvitem fi,
EPMDocument doc,
FVMOUNT M
where
order by
mas.cadname,
ver,
role
srohde1-VisitorAuthor
Thank you very much , thats exactly what I needed.
