Identifying HARNESS part object
  • March 12, 2012
  • 2 replies
  • 712 views
Hello folks,
Can you help in providing the needed APi's in identifying the CAD part to be a sub-type of HARNESS.
I am able to do it for a SHEET METAL via epmDoc.getdocSubType () ...., where as it retuns NULL for HARNESS parts.
Has any one face a similar issue ,pls provide your suggestions,
Sriram Rammohan
Sounds like you didn't load HARNESS into the types. Or the data was migrated without it set. This all sounds completely custom, so I doubt you'll get much of a response beyond this.
Thank David , do you mean to say to set the attribute in Pro-E tool kit identifying the obj as Harness and then retiving the obj in WC using IBA , etc and so ?
