Listing of all library objects
OK, I've been trying long enough and decided I just don't have the
expertise (and time) to figure this out.
I've got a pretty neat sql scripts (got if from this exploder) which
reports all objects in Intralink 3.4 on one line including it's
Folderpath and it's Vaultpath. (see below). But I just found out that
this list does not include the library objects (generics and instances).
I'm sure there is enough expertise out there which can change the code
below to create a similar list for all library objects.
(at least for all generics and perhaps also the folderpaths and generics
for all instances)
Can anyone help me out here?
==== start objectfoldervaultlist.sql ========
SET PAGES 0
set lines 500
set trimspool on
--SET FEED OFF
SET HEAD OFF
SET VERI OFF
SET ARRAYSIZE 1
SELECT FOLPATH||','
||PINAME||','||PIVREV||'.'||PIVVer||','||BRPATH||','
||FSVPORT||'@'||POOLHOST||':'||POOLPATH||'|'||PIVFMAPNAME||' - '
||pivfid
FROM (SELECT DISTINCT
PINAME, PIVREV, PIVVer, BRPATH, FSVPORT,
FOLPATH,
POOLHOST, POOLPATH, FMAPNAME PIVFMAPNAME, pivfid, PIVFNAME
FROM pdm.pdm_file,
PDM.PDM_FOLDER,
PDM.PDM_POOL, PDM.PDM_PRODUCTITEMVERFILE, PDM.PDM_FILESERVER,
PDM.PDM_PRODUCTITEMVERSION, PDM.PDM_BRANCH,
PDM.PDM_PRODUCTITEM
WHERE PDM.PDM_POOL.POOLID = PDM.PDM_file.POOLID
and pdm.pdm_file.fid = pdm.pdm_productitemverfile.fid
AND PDM.PDM_PRODUCTITEMVERSION.PIVID =
PDM.PDM_PRODUCTITEMVERFILE.PIVID
AND PDM.PDM_FOLDER.FOLID = PDM.PDM_PRODUCTITEM.FOLID
AND PDM.PDM_BRANCH.BRID = PDM.PDM_PRODUCTITEMVERSION.BRID
AND PDM.PDM_PRODUCTITEM.PIID = PDM.PDM_BRANCH.PIID
AND PDM.PDM_FILESERVER.FSVHOST = PDM.PDM_POOL.POOLHOST)
-- SPOOL OFF
EXIT
==== end objectfoldervaultlist.sql ========
Thanks in advance.
Kind regards,
Olaf Corten
Olaf Corten
CAD/PLM Manager, Besi Competence Center - Other Business Applications
Fico BV, Ratio 6, 6921 RW Duiven, The Netherlands
Tel.: +31 26 3196215
Fax: +31 26 3196200
Mobile: +31 644548554
www.fico.nl
for all instances)
SET PAGES 0
set lines 500
set trimspool on
--SET FEED OFF
SET HEAD OFF
SET VERI OFF
SET ARRAYSIZE 1
SELECT FOLPATH||','
||pivfid
FOLPATH,
FROM pdm.pdm_file,
PDM.PDM_FOLDER,
PDM.PDM_PRODUCTITEM
-- SPOOL OFF
EXIT
Thanks in advance.
Kind regards,
Olaf Corten
Olaf Corten
Fax: +31 26 3196200
www.fico.nl
