Promotion notice - modify attributes of attached EPMdocs?
I have a question that I think may need a JAVA guru to help with.
Basically, what we would would like to do is get the promotion notice workflow to automatically add the initials of the checker and approver and the associated dates toattributes in the EPMdocs attached to the promotion notice, so that when the drawing/ model changes state to checked or approved they have the neccesary data for the drawing borders.
Currently we have two workarounds neither of which is ideal:
1. designer completes the boxes before promoting the drawing
2. the checker and approver have to check out the drawing so they can modify the attributes (not using CAD tool), then check the item back in.
It would be much better if this could be automated.
Has anybody managed to do this sort of thing? If so, could you give us a hand?
we are using PDMlink 9.1 M030, with CATIA, Pro/E, UG & Solidworks
Cheers
Simon Lucas
