Redisplay of Workflow Variables after an Exception
  • February 8, 2011
  • 2 replies
  • 917 views
When a workflow activity throws an exception, all the visible workflow variables are re-displayed as their Internal Names NOT The 'Display Name'.
So for example I have two visible boolean variables:-
role_safety - Display Name 'Safety Lead'
role_proj_mgr - Display Name - 'Project Manager'
So the user sees:-
'Safety Lead' and
'Project Manager' in the activity
The user clicks 'Complete Task' - the transition code checks if they are both 'false', if they are then it throws an exception:-
The user now sees :-
'role_safety' instead of 'Safety Lead'
and
'role_proj_mgr' instead of 'Project Manager'
PTC have had this 4 months with no resolution.
Anyone out there able to help ?
Ian
You did not say what version you were at. I saw the same problem at
Windchill 9.1 M030, but the problem was corrected at 9.1 M050.
Don Thompson
Engineering Systems Analyst
Development Engineering
hermanmiller.com
616 654 5292 OFFICE
616 654 5279 FAX
616 836 8761 MOBILE
HermanMiller
iwebb1-VisitorAuthor
Thanks Don - We are on 9.1 M030
