Syntax for OIR of soft-type
  • February 20, 2010
  • 683 views
I've created a new soft-type under the Document type called First Article Inspection Report.
I'm confused as to the syntax I need in the OIR to associate it to this soft-type.
The 1st line of thedocument OIR looks like this:
<attributevalues objtype="wt.doc.WTDocument">
How should that be changed so it refers to the correct sub-type of WTDocument? Or don't I change that at all.
Dave Haigh
22-Sapphire I
February 20, 2010
Hover your mouse in the Type Manager over the created type and you'll see it. Add that to the type above it with the pipe (|) character as a separator.
Example for OTB Reference Document: wt.doc.WTDocument|com.ptc.ReferenceDocument
The first line of your OIR will say something (replace with your type): objType="wt.doc.WTDocument|com.ptc.ReferenceDocument">
