Feb 2, 2026 9:09 AM UTC
Update Windchill Apache because of OpenSSL
Version: Windchill 12.1
Use Case: Tips regarding OpenSSL Update
Description:
Hi
I have set Windchill version on 12.1, even if my question is probably valid for a whole range of other Windchill versions.
Last week there is released a new version of OpenSSL(3.6.1) because of 12 vulnerabilities. Since Windchill is delivered with Apache and thus OpenSSL. What is best way for updating.
If PTC is releasing a fix? If not what is best way to update Apache?
Feb 2, 2026 12:00 PM UTC
There is no documented or supported method to manually update Windchill's Apache or OpenSSL.
https://www.ptc.com/en/support/article/CS381201
This article shows the OpenSSL and Apache versions per Windchill release.
https://www.ptc.com/en/support/article/CS331220
If you don't see the version you want, log a call with PTC and ask them when it will be supported.  Also ask them if the bug list you referenced has any bearing on OpenSSL 3.0.X versions.  It may be that 3.6.1 is fixing bugs introduced in versions greater than the 3.0.x stream.
According to PTC, the only way to get security fixes for Apache and OpenSSL is by patching Windchill.  So, if you do see the version you want, update Windchill to the latest maintenance patch.
https://www.ptc.com/en/support/article/CS422246
avillanueva
23-Emerald II
Feb 2, 2026 3:10 PM UTC
@mmeadows-3 is right. I would also note that OpenSSL 3.0 is a LTS release which is why it appears to remain the one they deploy. This is similar to PTC releases. It is possible for you to deploy your own webserver to whatever version you want and not use the PTC supplied one. Curious is the CVEs fixed in 3.6.1 are back ported to 3.0.x.
jw_CS14-AlexandriteAuthor
Feb 2, 2026 3:27 PM UTC
They Did already
There is a new release of every version of the series (https://openssl-library.org/source/)
But why 3.0.x and not 3.5.x?
