BenPerry
Use of LOWER Operator in wt.query.SearchCondition
  • November 6, 2014
  • 1270 views
I am new to QuerySpec and SearchCondition. I have an SQL query that uses the LOWER() operator. Is it possible to use that operator in the wt.query.SearchCondition?
I have an array of usernames, but they are all in lowercase. I wish to query the database with the usernames, but in the database, they are stored as mixed case. Thus sometimes I don't get a result.
SQL:
select name,email from wtuser where lower(name) in ('ben.perry','otheruser1','otheruser2')
Results:
ben.perry ben.perry@company.com
otherUSER1 <email>
OtherUser2 <email>
wt.query.SearchCondition:
(this is a portion of the code in a FOR loop):
wt.query.SearchCondition(wt.org.WTUser.class,wt.org.WTUser.NAME,wt.query.SearchCondition.LIKE,userArray[z])
Results:
<the other users aren't found because userArray[] contains only lowercase characters>
Best answer by BenPerry
I opened a ticket and Mayur @ PTC helped with this.
From JavaDoc:
public SearchCondition(Class targetClass,String anAttribute,String value,boolean caseSensitive) throws QueryException
Therefore, add the false argument to the method at the end.
Correct:
wt.query.SearchCondition(wt.org.WTUser.class,wt.org.WTUser.NAME,wt.query.SearchCondition.LIKE,userArray[z],false)
(Original):
BenPerry
BenPerry15-MoonstoneAuthorAnswer
From JavaDoc:
Correct:
(Original):
