WGM message
  • October 16, 2014
  • 2 replies
  • 2212 views
Windchill 10.2 M20 WGM. Message when opening WGM. " ! A shared folder is selected for Windchill File System" The event viewer offers no info. What causes or how do I find out.
Best answer by ChrisSpartz
It sounds like you're getting the same error message as in CS167483. Take a look at this article and see if it helps:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS167483
jlambertz1-VisitorAuthor
Thank you. I don't know what the conflict is but setting to an unused folder seem to clear message. We don't use Solidworks so not sure if this is something that is application sensitive. I'm going to do a little more digging to understand what this variable is for. I did something to trip the error state.
