Windchill PDMLink 9.1 M050 & WF4 M130
I have user defined attributes defined in Windchill PDMLink. The same parameters are defined in Pro/E object drawings. I am not having success with populating parameters values in my drawings with the corresponding values from the user defined parameters in Windchill PDMLink.
I check the drawing out to a local workspace, modified the attribute values in a Windchill PDMLink local workspace and check in the drawing. The attribute values are correct for the checked in object and when I open this drawing in Pro/E the corresponding parameter values are empty.
How can I get the Windchill PDMLink attribute values to populate their corresponding parameters values in the drawing for use in the respective drawing table?
