Feb 6, 2024 5:00 PM UTC
Want to add customized action in Display Pane
Want to add customized action in Display Pane as shown in below attached image, See yellow highlighted rectangular BOX for the reference.
HelesicPetr
Feb 7, 2024 10:47 AM UTC
Hi @Vaibhav_Thakare
Not supported does not always means you can not do it.
Here you can find a way how to add a action for reporting
Report Selection List Customization
Here is example how to use own processor
How-to-add-a-custom-action-to-Windchill-PSB
Here is a thread where you can read what is possible
How-to-create-an-action-on-GWT-action-model-without-jsp
Also function name in XML Action.xml definition has to contains suffix string GWT do not forget it.
PS> for more information generally search for GWT Customization (Google Web Toolkit)
PetrH
Rocket_Max
Feb 7, 2024 1:20 AM UTC
The PSB is implemented using Google Web Toolkit (GWT) technology, and it is not supported to customize the functions built upon GWT toolkit
https://www.ptc.com/cn/support/article/CS165341?art_lang=en
HelesicPetr
Hi @Vaibhav_Thakare
PetrH
Feb 14, 2024 8:45 AM UTC
Hi HelesicPetr,
Thank you very much for your all time support.
