hide the solid model in a part
  • September 18, 2018
  • 7 replies
  • 5131 views
I'm not figuring out, how to hide the solid model in a part.
Help me please, i'm giving in crazy with this...
Best answer by Patriot_1776
It's not "extremely difficult", it's pathetically easy.  Can't be bothered to spend the 30 seconds needed to do it manually?  Create a layer in your start part like I did with rules forcing all solid geometry to be on the "Solid_Geometry" layer, and you're done.
Sheesh....
Create a layer and add "All Solid Geometry" to it.  Hiding this will hide the solid.
I tested it in Creo 2.0 ...
  • create new layer
  • place mouse cursor on solid geometry
  • click right mouse button
  • select Pick from List command
  • select SolidGeom item ... see picture
  • OK
Is there any way to create an "Idea" or "Enhancement" within these forums for this?
The ability to hide all solid geometry is crucial when working with solidifying surfaces that exist within the solid to be trimmed. It is a REQUIRED capability for all advanced modeling.
Adding all solid geometry to a layer and then hiding it is an extremely difficult/hidden way to do this very simple task, and the layer that is created has to be deleted later on if modelcheck is to be passed (which requires all layers to be blank, at my company at least).
StephenW
