sPurge 3.0
sPurge 3.0- The Tool to purge Pro/ENGINEER files available for new version PTC Creo 10.
BenLoosliAnswer
This should NOT be in the Ideas portion of the community.
PTC does supply a version of the purge.exe with Creo 10. Since I run Windchill, I do not need it.
Emeritus
Status changed to: Clarification Needed
Hi @RR_10444688!
Thank you for publishing your idea.
However, you give the bare minimum of information. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Here are a few examples of well documented ideas:
https://community.ptc.com/t5/Creo-Parametric-Ideas/Option-to-Import-STEP-file-as-Inseparable-Assembly-by-Default/idi-p/812924
https://community.ptc.com/t5/Creo-Parametric-Ideas/Eztol-Rename-action-not-synchronous-in-Eztol/idi-p/828000
https://community.ptc.com/t5/Creo-Parametric-Ideas/Always-enable-ability-to-Add-View-Label-in-a-drawing/idi-p/837630
Please elaborate within the next two weeks.
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
StephenW
@RR_10444688
Spekan Purge is a third party tool developed for Creo. I don't believe they are developing or distributing that product any longer
BenLoosli23-Emerald IIIAnswer
Emeritus
This post has been moved from the Ideas section, as it seems to be a technical inquiry.
