tangential placement
  • August 18, 2016
  • 2049 views
Hi all
it seems that something has changed since i used this function last time. We are using Creo 3 M100 now
I would like to place an assembly tangential to an other assembly but Creo takes always the "wrong" side of the tangent
so expected is this
but i always get this
I think to remember that you could switch the direction of the tangent in earlier Creo versions ....
is this function lost, am I doing something wrong?
regards Chris
Best answer by ChristophLatzer
I think i found the solution myself https://community.ptc.com/t5/Creo-Parametric-Ideas/Allow-tangent-constraint-to-flip/idi-p/460922 not part of Creo functionality ....
ChristophLatzer1-VisitorAuthorAnswer
