3-Newcomer
Is there any way KepserverEx can pull tag from FT Historian?
VladimirNAnswer
Take a look here:
VladimirN24-Ruby IVAnswer
Take a look here:
3-Newcomer
TCS Confidential
Emeritus
Hello @SV_10959502,
It looks like you have a response from a community member. If it helped to solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Support
Greetings,
Does this Post answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Mohit
