3-Newcomer
August 25, 2024
Is there any way KepserverEx can pull tag from FT Historian?
  • August 25, 2024
  • 3 replies
  • 1327 views
Best answer by VladimirN
Take a look here:
VladimirN24-Ruby IIIAnswer
Take a look here:
3-Newcomer
August 25, 2024
TCS Confidential
Community Moderator
September 4, 2024
Hello @SV_10959502,
It looks like you have a response from a community member. If it helped to solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Greetings,
Does this Post answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Mohit
