7-Bedrock
March 6, 2026
Black ground but feature could be added
  • March 6, 2026
  • 4 replies
  • 306 views
I am using Creo Parametric Release 11.0 and Datecode11.0.6.0
After installing PTC Creo (11.00.07), I attempted to open various files. However, only assembly (.asm) and part (.prt) files will open. When I view a part, the background is completely black.
No error messages. but Despite successfully creating and saving new sketches, the part view still shows a black background. Changing appearance settings did not resolve the issue. I still could not visit the part
    Best answer by MS_14519083
    @KenFarley
    The issue is solved after closing function (adding config: enable_fsaa, value:off).
    (PTC article: Article - CS417033, Graphics Window does not display any geometry or drawing in Creo Parametric 11)
    Moby
    7-Bedrock
    March 6, 2026
    Community Moderator
    March 13, 2026
    Hello @MS_14519083,
    It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
    KenFarley
    MS_145190837-BedrockAuthorAnswer
    7-Bedrock
    March 16, 2026
    @KenFarley
    Moby
