Jul 19, 2018 4:20 AM UTC
'Thing not Running' Issue
I am facing an issue when I am creating thing programatically. I know there are couple of good discussions already available on the portal. I think am following the necessary steps while creating things which are suggested, of Enabling and Restarting the thing.
This is not a very frequent error, and most of the time I don't get the 'Thing not running' exception, so I believe procedure is correct for most of the time, but the problem is, I am not able to identify the solution when this error comes.
I even tried to again restart and enable the thing when 'Thing not running' error comes, but still of no use. What is more weird is, when the thing is not running if I call the service 'IsEnabled' it returns true, and rest all other service gives exception, for example 'Get Description'.
Some posts are also taking about 'ghost entities' and are suggesting to restart the Tomcat, but in this particular case even that's not working for me.
I am using VirtualBox docker version of Thingworx
Some posts and topics that I referred are -
https://community.ptc.com/t5/ThingWorx-Developers/JavaScript-CreateThing-Thing-is-not-running/td-p/508232
https://community.ptc.com/t5/ThingWorx-Developers/Thing-ThingName-is-not-running/td-p/531655
https://community.ptc.com/t5/ThingWorx-Developers/Things-are-in-quot-Thing-is-not-Running-quot-state/td-p/503273
https://community.ptc.com/t5/ThingWorx-Developers/Creating-Things-but-not-running/m-p/507967#M5735
Any help would be appreciated.
Thanks in advance
Regards
Aditya Mittal
Jan 24, 2019 10:25 AM UTC
Did you find any solution to it, because we are facing exactly the same problem? Thanks in advance.
Jan 24, 2019 2:14 PM UTC
This problem can be cause by a lot of different things, if you can concrete a bit more your problem we may help.
