Statistical Monitoring with Descriptive Analytics Part 2
Step 5: Additional Services
The Trend, Range, and Threshold Services are some of the Services the Statistical Monitoring ThingShape offers. Below is a table of additional included Services.
Links to guides for using services like these to build complete IoT applications are found in the next step.
CalculationService NameDescription
Consecutive Points Based On a RangeGetNumberOfConsecutivePointsBasedOnARangeCalculate the number of points in the largest group of consecutive points meeting the range criteria.
Consecutive Points Based On a ThresholdGetNumberOfConsecutivePointsBeyondAThresholdCalculate the number of points in the largest group of consecutive points meeting the threshold criteria.
Number of Points with Percentage Change Out of RangeGetNumberOfPointsWithChangeRateOutOfRangeMonitor for how many pairs of consecutive points in a series have a numerical percentage change outside the defined range. If the first value in a pair is 0, the pair is not considered.
Step 6: Next Steps
Congratulations!
In this guide, you've learned how to:
  • Create a Value Stream
  • Create a Thing with the Statistical Monitoring Thing Shape
  • Modify a Property to record values to the Value Stream
  • Test built-in Services used in Statistical Monitoring
Learn More
We recommend the following resources to continue your learning experience:
CapabilityGuide
BuildGet Started with ThingWorx for IoT
BuildBuild a Predictive Analytics Model
BuildOperationalize an Analytics Model
Additional Resources
If you have questions, issues, or need additional information, refer to:
ResourceLink
CommunityDeveloper Community Forum
SupportDescriptive Analytics Help Center
