Jaime_Lee
Community Manager
April 2021 Most Noteworthy Posts!
Noteworthy April 2021 Posts
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for April! See if your community username made this list! Or, read more about a topic that interests you!
1. Creo:  @seanmcdonn  revitalized the 2014 conversation Creo Parameters and Drawing Text Formatting started by @BreMiSt
Thank you, @dschenken  @StephenW  @TomU @dgschaefer   @dbaum_200319   @gbronke @dnordin @pausob   for participating!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Creo-Parameters-and-Drawing-Text-Formatting/m-p/724864
2. Creo: @msteffke  received an Accepted Solution from  @RPN for his thread ProSelection Array without user interaction. Thank you,  @FV_01  for participating!
https://community.ptc.com/t5/Customization/ProSelection-Array-without-user-interaction/m-p/723447#M10242
3. ThingWorx:   @MFritzhand   received an Accepted Solution for the inquiry JSON to InfoTable
https://community.ptc.com/t5/ThingWorx-Developers/JSON-to-InfoTable/m-p/723937#M51554
4. ThingWorx :   @SG_9012314   received help with a ThingWorx Installation with postgreSQL for windows
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-installation/m-p/724267
5. ThingWorx:   @ML_8931370  asked about Error installation ThingWorx Foundation 9.1
https://community.ptc.com/t5/ThingWorx-Developers/Error-installation-Thingworx-Foundation-9-1/m-p/724053
6. ThingWorx:  @JanKerkhofs   asked about QR Code Extension on Marketplace?
https://community.ptc.com/t5/ThingWorx-Developers/QR-Code-Extension-on-Marketplace/m-p/724673
7. Vuforia:   @ASM asked about Multiple scan widget in 3D eyewear
 @whity  and @dsgnrClarK  thank you for participating to the conversation!
https://community.ptc.com/t5/Vuforia-Studio/Multiple-scan-widget-in-3D-eyewear/m-p/726687
8. Vuforia:  @Ace_Rothstein_315546  received and Accepted Solution for the inquiry How to create a fade in and fade out effect for a 3D Image when it is triggered for visibility.
https://community.ptc.com/t5/Vuforia-Studio/How-to-create-a-fade-in-and-fade-out-effect-for-a-3D-Image-when/m-p/689870
9. Vuforia:  @EEmmanuelLG  received an Accepted Solution for the issue around Can’t sign in VEC with organization account in HoloLens
https://community.ptc.com/t5/Vuforia-Studio/Can-t-sign-in-VEC-with-organization-account-in-HoloLens/m-p/721548
10. Windchill:  @khimani_mohiki  received an Accepted Solution from @d_graham  for the inquiry related to Creating, Storing & sharing Drawings
https://community.ptc.com/t5/Windchill/Creating-Storing-amp-sharing-Drawings/m-p/724369#M63858
Thank you,  @BenLoosli  and  @avillanueva  for also contributing to the conversation!
11. Windchill: @SV_9649587  received a “swift response” from @Ajit_Kulkarni   on how to Publish PDF to drawing content as attachment
Thank you,  @d_graham  for participating also in the conversation!
https://community.ptc.com/t5/Windchill/Publish-PDF-to-drawing-content-as-attachement/m-p/722545
12. Windchill: @arajagopal @joe_morton  @BenLoosli @mmeadows-3 @mmeadows-3  and  @rhart
had a conversation around EPMDocument subtyping.
https://community.ptc.com/t5/Windchill/EPMDocument-subtyping/m-p/725401
13. Windchill:  @aachanta  received an Accepted Solution from @BenPerry  for the inquiry around Windchill API to check if a certain version of object is published or not and then publish
Another great contribution from d_graham as well!
https://community.ptc.com/t5/Windchill/Windchill-API-to-check-if-a-certain-version-of-object-is/m-p/724590
14. Windchill:  @SvenVanDroogenb received an Accepted Solution from @d_graham for Routing/Tallying Expression in Assigned Activity
https://community.ptc.com/t5/Windchill/Routing-Tallying-Expression-in-Assigned-Activity/m-p/725334#M63885
15. Arbortext:  @BE_9902721  received help from @bfriesen  for IsoDraw 7.3 does not show colors when importing CGM
https://community.ptc.com/t5/Arbortext/IsoDraw-7-3-does-not-show-colors-when-importing-CGM/m-p/724278
16. Arbortext: @Tusken_Raider @Tusken_Raider_422171 received help from @DmitryTsarev  Using HTTPS/SSL to connect to Arbortext Publishing Engine
https://community.ptc.com/t5/Arbortext/Using-HTTPS-SSL-to-connect-to-Arbortext-Publishing-Engine/m-p/708018
17. Arbortext: @Tusken_Raider received some insight from @GarethOakes  and @DmitryTsarev about Error AutoNumber Action Failed Number of conflicts
https://community.ptc.com/t5/Arbortext/Has-anyone-seen-this-error/m-p/723144
18. Windchill SSE: @amatai  revitalized the topic Message: system clipboard data unavailable originally started by  @wcatunda-2
Thank you, @Ted_Lin  @fbamberg  and @einsor  for contributing to the conversation!
https://community.ptc.com/t5/Windchill-Systems-Software/Message-system-clipboard-data-unavailable/m-p/105321
19.  Windchill SSE:   @BaluSri  received a reply from @kjain2  Assignment trigger meant to clear rich-text is configured with MKS HTML tag and a non-breaking space
https://community.ptc.com/t5/Windchill-Systems-Software/Assignment-trigger-meant-to-clear-rich-text-is-configured-with/m-p/724419
20.  Mathcad:  @Cornel  received an Accepted Solution from @Werner_E  to his topic related to Matlab Code to Mathcad (15) – FE
Thank you   @terryhendicott for also contributing to the thread!
https://community.ptc.com/t5/PTC-Mathcad/Matlab-Code-to-Mathcad-15-FE/m-p/725409
21. Mathcad: We can always count on @Fred_Kohlhepp  to provide some FUN to Mathcad forums with his Just for fun, hovering helicopter post.
https://community.ptc.com/t5/PTC-Mathcad/Just-for-fun-hovering-helicopter/m-p/723289
22. Mathcad:  @prop_design  gave a shout out to other community members for helping with the Two Square Wave Vibration Examples post. Awesome Teamwork!
Special recognition to contributors @-MFra- and @LucMeekes
https://community.ptc.com/t5/PTC-Mathcad/Two-Square-Wave-Vibration-Examples/m-p/725382
