Jaime_Lee
Community Manager
August 2021 Noteworthy Posts
Noteworthy August 2021 Posts
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging or most viewed PTC Community threads for August 2021! See if your community username made this list! Or, read more about a topic that interests you!
1. Mathcad: @SPRstructur started the discussion Error Calculating
Thank you, @LucMeekes, @ttokoro, @terryhendicott, and @ChrisKaswer for participating in the conversation!
https://community.ptc.com/t5/PTC-Mathcad/Error-Calculating/m-p/743500
2. Mathcad: @SFares received an Accepted Solution from @LucMeekes for the post about Nonlinear Incremental/ Iterative solution Newton-Raphson
Thank you, @StuartBruff, @VladimirN, @tokoro, and @Structures_401  for participating in the conversation!
https://community.ptc.com/t5/PTC-Mathcad/Nonlinear-Incremental-Iterative-solution-Newton-Raphson/m-p/745718
3. Mathcad: @ValeryOchkov post about the  New bilingual book on Mathcad  received top views in August. Be sure to check it out!
https://community.ptc.com/t5/PTC-Mathcad/New-bilingual-book-on-Mathcad/m-p/745427
4. Creo: @cadbart received help for the inquiry about Cannot solidify (remove material) with copied surface. Thank you, @tbraxton, @Patriot_1776, @rzukowski, and @pimm for providing such great advice!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Cannot-solidify-remove-material-with-copied-surface/m-p/741991
5. Creo: Great discussion about Symmetric revolve 359.75 degrees (for Creo 8.0) started by @SYNDAKIT Thank you, @StephenW, @Chris3, Patriot_1776, @kdirth, and @MartinHanak for contributing to the conversation.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Symmetric-revolve-359-75-degrees/m-p/741939
6. Creo: 2015 post Simplify a Assembly Into a Part started by @gnewman received top views in August!
Thank you StephenWilliams, dgschaefer, @TomU, @JLG, @jgp_shanghai, @unknown, and @RaphMORIN, @TomD.inPDX   for participating in the discussion.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Simplify-a-Assembly-into-a-part/m-p/433175
7. ThingWorx: The post by @XJ_9993206 Where to find Mail Extensions version 4.0 received an Accepted Solution! Thank you, @DmitryTsarev for participating in the thread!
https://community.ptc.com/t5/ThingWorx-Developers/Where-to-find-Mail-Extensions-version-4-0/m-p/741270
8. ThingWorx: @sankararaman started a discussion about Thingworx Composer and Runtime not opening
Thank you, DmitryTsarev and @GunwantP for contributing to the conversation.
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-Composer-and-Runtime-not-opening/m-p/743462
9. ThingWorx: @sabharees received an Accepted Solution for the post Postgres Persistence provider {Data store unknown error
https://community.ptc.com/t5/ThingWorx-Developers/Postgres-Persistence-provider-Data-store-unknown-error/m-p/745224
10. ThingWorx: @RM12 received an Accepted Solution for the post How to create get API in Thingworx with getting all data json format.
https://community.ptc.com/t5/ThingWorx-Developers/How-to-create-get-API-in-Thingworx-with-getting-all-data-json/m-p/743214
11. Vuforia: @KatrinC started a discussion about How to spawn 3D models dynamically by pressing a button within experience. Thank you, @whity @pawelek103, and @Suraj_Patil for participating in the conversation!
https://community.ptc.com/t5/Vuforia-Studio/How-to-spawn-3D-models-dynamically-by-pressing-a-button-within/m-p/746021
12. Vuforia: @Ike@ACE received an Accepted Solution for the post about .js Function Exection on Service Completion
https://community.ptc.com/t5/Vuforia-Studio/js-Function-Exection-on-Service-Completion/m-p/744895
13. Vuforia: @newieKek received an Accepted Solution for the inquiry about Deleting an Unloadable Experience in the Library in Vuforia View
14. Vuforia: @william_shih received an Accepted Solution for the post about How to apply a shader with model regular color, texture?
https://community.ptc.com/t5/Vuforia-Studio/How-to-apply-a-shader-with-model-regular-color-texture/m-p/742483
15. Windchill: @jwagh asked How do you manage your Cadworker settings and ME processes for checkin, revise?
Thank you @MikeLockwood TomU , @d_graham and @hoarnold for contributing to the discussion!
https://community.ptc.com/t5/Windchill/How-do-you-manage-your-Cadworker-settings-and-ME-processes-for/td-p/744843/page/2
16. Windchill: @Sulibo received an Accepted Solution from @BenLoosli for the inquiry How to make parts showing in 3D assembly model but now show in BOM
Thank you, @avillanueva for also participating in the conversation!
https://community.ptc.com/t5/Windchill/How-to-make-parts-showing-in-3D-assmebly-model-but-now-show-in/m-p/742386
17. Windchill: @JacobH revitalized a 2019 post by TomU Can a workflow robot assign a participant to a subsequent task?
Thank you, TomU, dgraham and @SEANPAN for participating in the thread!
https://community.ptc.com/t5/Windchill/Can-a-workflow-robot-assign-a-participant-to-a-subsequent-task/m-p/612896
18. Windchill: @KG_9957528 received an Accepted Solution from mlockwood for his post about ECN Rverse the ecn workflow to particular time. Thank you, avillanueva and d_graham for also participating in the conversation!
https://community.ptc.com/t5/Windchill/ECN-Rverse-the-ecn-workflow-to-particular-time/m-p/743969
19. Arbortext: @ED_9927023 received an Accepted Solution from @GarethOakes for the inquiry ACL-How to replace all characters provided a file path
https://community.ptc.com/t5/Arbortext/ACL-How-to-replace-all-characters-provided-a-file-path/m-p/745322
20. Arbortext: @pkhandelwal started the conversation about Arbortext PE 8.0.2.0 PDF composition Fails
Thank you, GarethOakes for participating in the conversation!
https://community.ptc.com/t5/Arbortext/Arbortext-PE-8-0-2-0-PDF-composition-Fails/m-p/743273
21. Arbortext: @BenjaminCoast asked about Issue with our chgstatus attribute
Thank you, @JamesCLS and GarethOakes for participating in the conversation!
https://community.ptc.com/t5/Arbortext/Issue-with-our-chgstatus-attribute/m-p/745472
