Jaime_Lee
Community Manager
January 2021 Noteworthy Community Posts
ENGAGE= KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for January!  See if your community username made this list! Or, read more about a topic that interests you!
  1.  Creo: @tbraxton  helped @AE_9609989  with tracking down a circular reference.
https://community.ptc.com/t5/3D-Part-Assembly-Design/tracking-down-a-circular-reference/m-p/709384#M118442
  1. Creo:  tbraxton and @KenFarley  provided answers for the question from @cadbart  about How to move `copy` feature from one part to another
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-move-copy-feature-from-one-part-to-another/m-p/706489
  1. Creo:@Sandy1 asked  Is it possible to create a sketch from 3D sectional view creo? And  @LukaszMazur provided an Accepted Solution.  Thank you,  @mwodarz_INNEO  and @Cormack87  for participating in the thread!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Is-it-possible-to-create-a-sketch-from-3D-sectional-view-creo/m-p/708102
  1. ThingWorx:  @jensc  is asking about how to Get name of service inside service and uncovered that a new feature request was in order!
https://community.ptc.com/t5/ThingWorx-Developers/Get-name-of-service-inside-service/m-p/707620
  1.  ThingWorx:   @SB_9732186  started a great conversation about Close Mashup on Button Click (not popup)  Thank you @Anonymous , @VS_9760165 , and @odukiya for participating!
https://community.ptc.com/t5/ThingWorx-Developers/Close-Mashup-on-Button-Click-not-popup/m-p/706266
  1. ThingWorx:   @NHorst  is asking about Cannot Purge Value Stream / Thing logged data  Thank you @Ciprian-Traian  and  @Ashritha  for contributing to the conversation!
https://community.ptc.com/t5/ThingWorx-Developers/Cannot-Purge-Value-Stream-Thing-logged-data/m-p/705750
  1.  ThingWorx:   @TanmeyTWX   started a discussion about Webframe not loading cross frame content
https://community.ptc.com/t5/ThingWorx-Developers/Webframe-not-loading-cross-frame-content/m-p/707791
  1.  Vuforia:  Very thorough answers and great replies from @RolandRaytchev ,  @dsgnrClarK  , and sgreywilson  for  the question from   @DiSiDtwin  about Transferring an image to twx.
https://community.ptc.com/t5/Vuforia-Studio/Transferring-an-image-to-twx/m-p/703693
  1.  Vuforia:  @MaximeDid received an Accepted Solution from dsgnrClarK Change a color of the 3D label via .js
https://community.ptc.com/t5/Vuforia-Studio/Change-a-color-of-the-3D-label-via-js/m-p/705748#M9136
  1.  Vuforia:   @LS_9776545     asked a great question about How to import external Javascript file
Great advice from the PTC Team and dsgnrClarK!
https://community.ptc.com/t5/Vuforia-Studio/How-to-import-external-Javascript-file/m-p/709551
  1.  Vuforia:   @AS16  received an Accepted Solution for the question about  Display the next step name from Creo Illustrate.
https://community.ptc.com/t5/Vuforia-Studio/Display-the-next-step-name-from-Creo-Illustrate/m-p/707339#M9181
12.  Windchill:  @gprajeesh77 asked about 12.0.1.0 installation with LDAP v3 compliant OpenDJ and received an Accepted Solution from @TomU with assistance of an older eSupport Help article for version 11.2.1.0.  Great Knowledge sharing!
https://community.ptc.com/t5/Windchill/12-0-1-0-installation-with-LDAP-v3-compliant-OpenDJ/m-p/707556#M63397
  1.  Windchill:  Lively conversation with referral to a you tube link around the topic of  Techsoft Model Search started by  @Natem0613  Thank you @LawrenceS , @TomU, @phinterdorfer, @ronan, @nsteward, and @mdebower for contributing to the thread!
https://community.ptc.com/t5/Windchill/Techsoft-Model-Search/m-p/612910
  1. Windchill:  @bcedar revitalized a thread started by @TomU about  How to track and manage changes to the Windchill installation
Thank you @AndyHermanson, @mlockwood-2, @jvonzastrow1, @fivig, @RandyJones, and @gprajeesh77 for contributing to the thread!
  1.  Windchill:  @shetakesubhash7  received an Accepted Solution from @bmr  for his question about How to identify WTPart being created using SAVE AS action
Thank you @Florent for contributing to the thread!
 16.  Arbortext:   @mwillerson helped this PTC Post Arbortext 8.1.0.0 has released become a top post for January!  Thank you @bfreisen for continuing the conversation
https://community.ptc.com/t5/Arbortext/Arbortext-8-1-0-0-has-released/m-p/694223
  1. Abortext:   @ptc-1178792 asked a question about Licence Management  Thank you, @GarethOakes and @VladimirN for contributing to the conversation!
https://community.ptc.com/t5/Arbortext/Licence-Management/m-p/703511
  1. Arbortext:  @Tusken_Raider is looking for answers for his question about Using HTTPS/SSL to connect to Arbortext Publishing Engine
https://community.ptc.com/t5/Arbortext/Using-HTTPS-SSL-to-connect-to-Arbortext-Publishing-Engine/m-p/708018
  1. Arbortext:   @dgopois asked about With the ACL language, how to activate the “Entities” menu without loading a document.
https://community.ptc.com/t5/Arbortext/With-the-ACL-language-how-to-activate-the-quot-Entities-quot/m-p/707561
  1. Arbortext: @amund received an Accepted Solution from @ascott for Email Notification via CLI
https://community.ptc.com/t5/Windchill-Systems-Software/Email-Notification-via-CLI/m-p/708361
  1. Arbortext: @jarcher3 re-energized a thread Can Requirement Connector be used without a round trip configuration started by @AK_9623847 in September 2020 and received an Accepted Solution by @mbathala.
https://community.ptc.com/t5/Windchill-Systems-Software/Can-Requirement-Connector-be-used-without-a-round-trip/m-p/687333
  1.  Windchill SSE:  @Zeiad-Alkassem received an Accepted Solution for his topic about Using the environment variable In the custom menu
https://community.ptc.com/t5/Windchill-Systems-Software/Using-the-environment-variable-In-the-custom-menu/m-p/708362
23.  Windchill SSE:  @rteifke and @ascott are discussing Programmatically getting a list of documents that were branched from a single document in Integrity
https://community.ptc.com/t5/Windchill-Systems-Software/Programmatically-getting-a-list-of-documents-that-were-branched/m-p/709520
  1.  Mathcad:  We can always count on @ValeryOchkov to start an engaging thread.  The topic raised this month around Leo Tolstoy and Mathcad  Thank you @Werner_E for contributing to the thread!
https://community.ptc.com/t5/PTC-Mathcad/Leo-Tolstoy-and-Mathcad/m-p/707378#M193915
 25.  Mathcad: In January, @IvI107 answered his own question about  How to plot a point in 3-D and Rotation of the point?  Thank you, @ttokoro and @Werner_E for contributing to the conversation!
https://community.ptc.com/t5/PTC-Mathcad/How-to-plot-a-point-in-3-D-and-Rotation-of-the-point/m-p/699363
  1.  Mathcad:  Fun challenge from @Fred_Kohlhepp A water flow problem resolved (Accepted Solution) by @ AlanStevens.  Thank you to @ValeryOchkov and @BillWadsworth for playing along!
https://community.ptc.com/t5/PTC-Mathcad/A-water-flow-problem/m-p/708221#M194021
