Emeritus
PTC Community Monthly Stand-Out January 2024
See the Top Community Engagers and the Top Noteworthy posts for the month of January..
Top January 2024 Community Engagers:
@HelesicPetr @avillanueva @MartinHanak @tbraxton @Werner_E @LucMeekes @terryhendicott @KenFarley @jbailey @StephenW @Michael @VladimirN @Hari_Vara @ttokoro @Patriot_1776 @SweetPeasHub @Arun_C @Velkumar @Divyanshi @pshepherdson
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for January 2024!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: cspinelli @RP_10384451asked about CSYS ALWAYS VISIBLE. Solution was provided by kdirth. Thank you @MartinHanak, @mkajdan and @aputman for your contributions as well.
@Lars_F
https://community.ptc.com/t5/3D-Part-Assembly-Design/CSYS-ALWAYS-VISIBLE/m-p/927527#M133263
2. Creo: Carol_88 received an accepted solution from  for topic Dimension missing when importing in Drw. drawing.Thank you @BenLoosli for your contribution as well.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Dimension-missing-when-importing-in-Drw-drawing/m-p/924387#M133004
3. Creo: Thank you kdirth@StephenW @YaroslavSinfor providing an accepted solution for ProFeature on this topic scaling Curve from Equation. Thank you @tbraxton for your contribution as well.
@DS_10868229
https://community.ptc.com/t5/3D-Part-Assembly-Design/scaling-Curve-from-Equation/m-p/926839#M133212
4. Creo: MORECREO@AB_10071442 needed help with this topic - Managing Single Part Drawings and Hidetaka@tbraxton offered him an accepted solution. Thank you @MartinHanak for your contribution as well.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Managing-Single-Part-Drawings/m-p/925843#M133151
5. Creo: A question about How to show thread when the axes are hidden was posted by vincecatlin@gfraulini and an Accepted Solution was provided by Hidetaka.
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-show-thread-when-the-axes-are-hidden/m-p/925311#M133125
6. ThingWorx: DanZ@Sathishkumar_C gave an Accepted Solution to Jamal8548 for the topic Validator Function is not working as expected. Thank you @nmutter, @nmilleson, @Arun_C for your contribution as well.
https://community.ptc.com/t5/ThingWorx-Developers/Validator-Function-is-not-working-as-expected/m-p/925746#M65251
7. ThingWorx: The topic Double click event alternative posted by AC_10460579@JK_10565232 received an accepted solution provided by VladimirRosu.
https://community.ptc.com/t5/ThingWorx-Developers/Double-click-event-alternative/m-p/928248#M65384
8. ThingWorx: Bikash_Panda@Rocko provided a speedy response and Accepted Solution to the inquiry by AP_10343008 about how to get count of occurrences using Infotable API.
https://community.ptc.com/t5/ThingWorx-Developers/how-to-get-count-of-occurrences-using-Infotable-API/m-p/927122#M65304
9. ThingWorx: oskarberntorp had an issue with I d return of the correct type, but get org.mozilla.javascript.UniqueTag@3b4f00ba: NOT_FOUND and Bikash_Panda@TonyZhang@ShirishMorkhade_238755 provided a quick Accepted Solution. Thank you @Velkumar for your contribution as well.
https://community.ptc.com/t5/ThingWorx-Developers/I-d-return-of-the-correct-type-but-get-org-mozilla-javascript/m-p/925793#M65254
10. ThingWorx: CZ_9645217@ZbigniewK posted the topic How to automatically trigger the execution of a thing service after a thingworx reboot and received an Accepted Solution from Velkumar.
11. Vuforia: JH_10275801@AlexK shared a post about Proposal to Increase Photo Resolution of Camera Widget on Hololens with View App.
Thank you @whity for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Proposal-to-Increase-Photo-Resolution-of-Camera-Widget-on/m-p/924765#M12248
12. Vuforia: AK_10927062@WZ_10636454 posted the topic Not able to open Studio and received an Accepted Solution from kesingh.
13. Windchill: Sandy7@OnurNalbantgl posted the topic Build action issue and received an Accepted Solution by
https://community.ptc.com/t5/Windchill/Build-action-issue/m-p/925744#M77821
14. Windchill: Srikanth1@Brndn4 asked about Chose between Product and Library and @mmeadows-3 provided the Accepted Solution.
https://community.ptc.com/t5/Windchill/Chose-between-Product-and-Library/m-p/926205#M77668
15. Windhill: MS_Santos@Dennis_V_NL asked about integrate Windchill with Active Directory with an Acccepted Solution from .
https://community.ptc.com/t5/Windchill/integrate-Windchill-with-Active-Directory/m-p/927779#M77881
16. Windchill: smcvr asked about Can I create a document using the program from the object in the attachment table? and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Can-I-create-a-document-using-the-program-from-the-object-in-the/m-p/927668#M77865
17. Mathcad: AL_10888052 needed help with Varying cross section along length of span (x) via Programming in MathCAD solution needed! and  provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Varying-cross-section-along-length-of-span-x-via-Programming-in/m-p/917493#M209696
18. Mathcad: PW_10297783@justhumm needed with ODE error and  helped with an Accepted Solution.
https://community.ptc.com/t5/Mathcad/ODE-error/m-p/925336#M210112
19. Mathcad: VG_10714868 asked about Creating gear Involute profile in Mathcad software
and  provided the Accepted Solution.
https://community.ptc.com/t5/Mathcad/Creating-gear-Involute-profile-in-Mathcad-software/m-p/926700#M210188
20. Mathcad: VG_1071486 asked about Defining variables for solve with an Acccepted Solution from .
https://community.ptc.com/t5/Mathcad/Defining-variables-for-solve/m-p/926439#M210164
