Emeritus
PTC Community Monthly Stand-Out February 2024
See the Top Community Engagers and the Top Noteworthy posts for the month of February.
Top February 2024  Community Engagers:
@HelesicPetr @MartinHanak @Werner_E @avillanueva @tbraxton @StephenW @jbailey @LucMeekes @BenLoosli @lvl107 @kdirth @KenFarley @MA8731174 @AV_10867476 @nmilleson @Dobi @Marco_Tosin @ProFeature @rmast @terryhendicott
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for February 2024!  See if your community username made this list!  Or, read more about a topic that interests you!
1.  Creo: @Chris3 asked about Lattice by shelling.  Great contributions by @MartinHanak, @Dale_Rosema. Solution provided by @tbraxton.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Lattice-by-shelling/m-p/931860#M133576
2.  Creo:  @MH_10366957 received an accepted solution from @ysinitsyn for topic  Toolkit Scripts Receiving failed to start error  @MartinHanak @FV and @MH_10366957 thank you for participating in the conversation!
https://community.ptc.com/t5/Customization/Toolkit-Scripts-Receiving-failed-to-start-error/m-p/842212
3. Creo:  An interesting conversation with @bmancini and @wiUser  around Define what to see and what to hide by default in a custom drw symbol
https://community.ptc.com/t5/3D-Part-Assembly-Design/Define-what-to-see-and-what-to-hide-by-default-in-a-custom-drw/m-p/928396#M133307
4.  Creo: rburk needed help with 2D drawing view issue with swept trajpar wire bundle and received an accepted solution from @aputman
https://community.ptc.com/t5/3D-Part-Assembly-Design/2D-drawing-view-issue-with-swept-trajpar-wire-bundle/m-p/932626#M133625
5.  Creo: A question about DXF exporting of flat - Layer Control was posted by msteffke and an Accepted Solution was provided by !
https://community.ptc.com/t5/3D-Part-Assembly-Design/DXF-exporting-of-flat-Layer-Control/m-p/932677#M133635
6.  ThingWorx: DanZ gave an Accepted Solution to natpaa@DanZ for the topic Menubar-widget, changing icon size.
https://community.ptc.com/t5/ThingWorx-Developers/Menubar-widget-changing-icon-size/m-p/933540#M65755
7.  ThingWorx: The topic Thingworx 9.5: In Fileupload widget upload button on disabled state is getting misaligned was posted by Anjaneyulu2705 and an accepted solution provided by Velkumar..
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-9-5-In-Fileupload-widget-upload-button-on-disabled/m-p/933615#M65758
8.  ThingWorx: Arun_C provided a speedy response and Accepted Solution to the inquiry by Jamal8548   about Import Data from Excel sheet to Thingworx DATATABLE.
https://community.ptc.com/t5/ThingWorx-Developers/Import-Data-from-Excel-sheet-to-Thingworx-DATATABLE/m-p/931758#M65678
9.  ThingWorx: YC_10946483 needed help with add a subscription to thing via rest api. Velkumar provided a speedy response and Accepted Solution
https://community.ptc.com/t5/ThingWorx-Developers/add-a-subscription-to-thing-via-rest-api/m-p/930702#M65558
10.  ThingWorx: SKannapiran  posted the topic "ThingWorx Device Id" and received an Accepted Solution from bchaudhary.
https://community.ptc.com/t5/ThingWorx-Developers/quot-ThingWorx-Device-Id-quot/m-p/933235#M65735
11.  Vuforia: armink shared a post about How to show/hide a waypoint and play specific sequences right after arriving/finding to the waypoint and received an Accepted Solution from ptc-1155647
https://community.ptc.com/t5/Vuforia-Studio/How-to-show-hide-a-waypoint-and-play-specific-sequences-right/m-p/930785#M12303
12. Vuforia: AlexK posted a topic about Import Cortona3D Animations. Thank youfor the solution!
https://community.ptc.com/t5/Vuforia-Studio/Import-Cortona3D-Animations/m-p/927496#M12275
13.  Windchill: Sandy7 posted the topic deleting the instace from windchill and received an Accepted Solution by @avillanueva.
https://community.ptc.com/t5/Windchill/deleting-the-instace-from-windchill/m-p/930905#M78361
14.  Windchill: AM_10644680 asked about @odata.bind and received an Accepted Solution from d_graham.
https://community.ptc.com/t5/Windchill/Is-it-possible-to-automatically-recompute-LDAP-groups-on-an/m-p/928928#M78069
15.  Windhill: ThreeBlindMice asked about Overwriting Creo View Adapters for Windchill with an Acccepted Solution by .
https://community.ptc.com/t5/Windchill/Overwriting-Creo-View-Adapters-for-Windchill/m-p/932694#M78572
16.  Windchill: ZL_10925195 asked about After starting the workflow, the entries in the WfPropagationQueue queue are always in the Executing state and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/After-starting-the-workflow-the-entries-in-the/m-p/933059#M78623
17.  Windchill: K_Patil had an Allocated part shows design view in structure (Windchill Version 11.1 M020 CPS 22) inquiry.  delivered an Accepted Solution.
https://community.ptc.com/t5/Windchill/Allocated-part-shows-design-view-in-structure-Windchill-Version/m-p/932749#M78574
18.  Mathcad: ttokoro posted the topic Puzzle-35. Find the Length DE. ABCD is rectangular. 5 areas are same sizes. AB=13 cm and  provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Puzzle-35-Find-the-Length-DE-ABCD-is-rectangular-5-areas-are/m-p/932495#M210457
19.  Mathcad: GR_4797597 tried to stump the Mathcad Community with the post genfit not working as expected. thank you for the solution!
20.  Windchill SSE: Chittaranjan_11 asked about How to export "Test Result" tab data from Testcase type into MS Excel and KartikOak provided an Accepted Solution.
https://community.ptc.com/t5/Windchill-Systems-Software/How-to-export-quot-Test-Result-quot-tab-data-from-Testcase-type/m-p/931763#M8012
21. Arbortext: gbélanger asked about Validation on document before to save in Arbortext Editor. and GarethOakes @RickSchoenprovided the Accepted Solution.
https://community.ptc.com/t5/Arbortext/Validation-on-document-before-to-save-in-Arbortext-Editor/m-p/933399#M33086
