Emeritus
PTC Community Monthly Stand-Out September 2023
See the Top Community Engagers and the Top Noteworthy posts for the month of September.
Top September 2023 Community Engagers:
@HelesicPetr @Werner_E @MartinHanak @avillanueva @tbraxton @Cornel @LucMeekes @terryhendicott @StephenW @Velkumar @Arun_C @kdirth @BenLoosli @VladimirN @Dale_Rosema @Amirtharaj_K @ttokoro @Pettersson @Dobi @KenFarley @TomU @lvl107 @ScottMorris @Marco_Tosin
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for September 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: MN_10661566  asked about Creo distribution tool (nmsd) exe doesnt terminate even after conversion is over. Solution was provided by @MartinHanak
@Lars_F
 https://community.ptc.com/t5/3D-Part-Assembly-Design/Creo-distribution-tool-nmsd-exe-doesnt-terminate-even-after/m-p/904629#M131494
2. Creo: pobsd @CR_9888056received an accepted solution from kdirth for topicInquiry Regarding Flat Pattern Generation and Feature Suppression in Image? Thank you@StephenWfor your contributions.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Inquiry-Regarding-Flat-Pattern-Generation-and-Feature/m-p/903549#M131406
3. Creo: Thank you @YaroslavSinfor providing an accepted solution for D_Hale on this topic Layer Rules and Submodel Selection Behavior Issues. Thank you@pausobfor your contributions as well.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Layer-Rules-and-Submodel-Selection-Behavior-Issues/m-p/903562#M131409
4. Creo: C-Peterson needed help with this topic - understanding scale in simulate result and SweetPeasHub offered him an accepted solution. Thank you @KenFarley for your contributions.
https://community.ptc.com/t5/Analysis/understanding-scale-in-simulate-results/m-p/902013#M11655
5. Creo: A question about Symbols on drawings show up as boxes
was posted by JM_8847223 and an Accepted Solution was provided by llie. Thank you  and sbukkawar for your contributions as well!
https://community.ptc.com/t5/Analysis/Symbols-on-drawings-show-up-as-boxes/m-p/901224#M11647
6. ThingWorx: Arun_C@TonyZhang gave an Accepted Solution to MH_10493873 for the topic What does it mean SelectedRows in the output of a service?
https://community.ptc.com/t5/ThingWorx-Developers/What-does-it-mean-SelectedRows-in-the-output-of-a-service/m-p/903297#M63891
7. ThingWorx: The topic Building dashboard for show data from Kepware ODBC Client posted by DR_10558933@Hrishabh.Sharma received an accepted solution provided by Sathishkumar_C. Thank you Arun_C for your contributions as well.
https://community.ptc.com/t5/ThingWorx-Developers/Building-dashboard-for-show-data-from-Kepware-ODBC-Client/m-p/901238#M63808
8. ThingWorx: Ashritha@S_Elsayed@Bikash_Panda provided a speedy response and Accepted Solution to the inquiry by
@S_Elsayed about How to have column headings in a table-style Collection Widget.
https://community.ptc.com/t5/ThingWorx-Developers/How-to-have-column-headings-in-a-table-style-Collection-Widget/m-p/902048#M63840
9. ThingWorx: DEV,YIDE,yoshi@RS_10021886 had an issue with "I can not set the LOCATION data into INFOTABLE" and VladimirRosu provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/I-can-not-set-the-LOCATION-data-into-INFOTABLE/m-p/903377#M63896
10. ThingWorx: RaulBernardo.PV posted the topic ThingWorx Installation Systems Requirements and received an Accepted Solution from .
https://community.ptc.com/t5/ThingWorx-Developers/ThingWorx-Installation-Systems-Requirements/m-p/902000#M63837
11. Vuforia: Aditya1702 shared a post about Creo Illustrate annotations in Vuforia Studio.
Thank you Suraj_Patil for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Creo-Illustrate-annotations-in-Vuforia-Studio/m-p/899286#M11988
12. Vuforia: IB_10645210 posted the topic Wayfinder settings /adjustments of waypoints
13. Windchill: libo-ME posted the topic Cant connect to windchill server after change the creo inner browser to Chrome and received an Accepted Solution by DevidasPawar.
https://community.ptc.com/t5/Windchill/Cant-connect-to-windchill-server-after-change-the-creo-inner/m-p/904840#M75079
14. Windchill: Dobi asked about the BOM report for CAD drawings on an EndItem eBOM and d_graham
provided the Accepted Solution.
https://community.ptc.com/t5/Windchill/BOM-report-for-CAD-drawings-on-an-EndItem-eBOM/m-p/903508#M74936
15. Windhill: SC_8321054 asked about Windchill Desktop Integration see only latest revision with an Acccepted Solution from Dobi. Thank you Marco_Tosin for your contribution!
https://community.ptc.com/t5/Windchill/Windchill-Desktop-Integration-see-only-latest-revision/m-p/902954#M74887
16. Windchill: LN_10490960 asked about Windchill Message of Update and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Windchill-Message-of-Update/m-p/903431#M74922
17. Mathcad: malmeida2019 needed help with director cosines and Cornel provided the Accepted Solution! Thank you  for your contribution!
https://community.ptc.com/t5/Mathcad/director-cosines/m-p/903267#M208814
18. Mathcad: SFares needed with Pasted a Material Table from Excel, Lookup values and  helped with an Accepted Solution.
https://community.ptc.com/t5/Mathcad/Pasted-a-Material-Table-from-Excel-Lookup-values/m-p/902901#M208794
19. Mathcad: CarlosRomero asked about "Simplify this solution block" and  provided the Accepted Solution.
https://community.ptc.com/t5/Mathcad/Simplify-this-solution-block/m-p/902607#M208757
20. Mathcad:TR_10796227 asked about Issues with units when using the solve function - MATHCAD 8.0.0.0 with an Acccepted Solution from @Dobi. Thank you ttokoro, @terryhendicottCornel @terryhendicottfor your contribution!
https://community.ptc.com/t5/Mathcad/Issues-with-units-when-using-the-solve-function-MATHCAD-8-0-0-0/m-p/902173#M208725
