Jaime_Lee
Community Manager
June 2021 Noteworthy Posts
ENGAGE - KUDO, REPLY, or SOLVE!
Below are the top engaging PTC Community threads for June!  See if your community username made this list! Or, read more about a topic that interests you!
Two older Creo posts received top views last month!
1. Creo: This post by @ptc-1647943  regarding How to show or draw center mark
received top views last month! Thank you @SkyKing @troesch  @DavidButz  @ptc-759514 @unknown  @ptc-5114571 @BrandonCroft  @ptc-4877655 @JWayman  @sdensberger  @TomD.inPDX  @Dale_Rosema  for contributing to this thread!
https://community.ptc.com/t5/3D-Part-Assembly-Design/how-to-show-or-draw-center-mark/m-p/116910
2. Creo: The Centre of Gravity (CG) for parts, assemblies and drawings to be shown as icon? started by @Bhoopathy received top views last month! Thank you @pimm  @KenFarley  @BrianTaylor  @Shahbazk61 @ghkhkjhkjh  @rrich-2  @AntonioVieira   @Roy_Crerar  for contributing to the thread!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Centre-of-Gravity-CG-for-parts-assemblies-and-drawings-to-be/m-p/318753
3. ThingWorx: @nahuel  received an Accepted Solution for his post Anomaly Detection Server Sizing
https://community.ptc.com/t5/ThingWorx-Developers/Anomaly-Detection-Server-Sizing/m-p/734369
4. ThingWorx:  @Raja_Redeem  inquired if Google Single sign-on can be implemented with ThingWorx application as SSO?
https://community.ptc.com/t5/ThingWorx-Developers/Can-Google-Single-sign-on-can-be-implemented-with-ThingWorx/m-p/731837
5. ThingWorx:  @cbaurand  asked about Mqtt extension “System” user
https://community.ptc.com/t5/ThingWorx-Developers/Mqtt-extension-quot-System-quot-user/m-p/732417
6. ThingWorx:  @vcavic  started a post Add some Attributes in Part List
https://community.ptc.com/t5/Thingworx-Navigate/Add-some-Attributes-in-Part-List/m-p/733439
7. ThingWorx: @AP_9587236  asked about the textbox widget…But why the default values of infotable not passing to the Textbox widget.??
https://community.ptc.com/t5/ThingWorx-Developers/textbox-widget/m-p/735528
8. Vuforia Studio: @Qwtll received an Accepted Solution for his post regarding 3D Panel distance (currently too far)
https://community.ptc.com/t5/Vuforia-Studio/3D-Panel-distance-currently-too-far/m-p/733071
9. Vuforia Studio:  @Qwtll  started another great post about How to reset whole experience while in AR World
https://community.ptc.com/t5/Vuforia-Studio/How-to-reset-whole-experience-while-in-AR-World/m-p/733776
10. Vuforia Studio:  @pjahn asked about Vuforia Experience Service on Linux-Best practive to run it as a daemon
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Experience-Service-on-Linux-Best-practive-to-run-it-as-a/m-p/733402
11. Windchill:  @ScottMorris  received an Accepted Solution from @Ajit_Kulkarni for the inquiry about
WVS CAD Worker Optimization and Memory Management  Thank you @rhart and @BjoernRueegg  for participating in the thread!
https://community.ptc.com/t5/Windchill/WVS-CAD-Worker-Optimization-and-Memory-Management/m-p/734997#M64223
12. Windchill:  @gmydoor-2  received an Accepted Solution from @d_graham  for his question regarding the code to republish failed jobs. Thank you, @BenLoosli  and  @BjoernRueegg  for contributing to the thread!
https://community.ptc.com/t5/Windchill/code-to-republish-failed-jobs/m-p/734179#M64183
13. Windchill: @khimani_mohiki posted about WVS AfterLoader deleting secondary content with helpful responses from @MikeLockwood and @d_graham
https://community.ptc.com/t5/Windchill/WVS-AfterLoader-deleting-secondary-content/m-p/731932
14. Windchill:  @Ajit_Kulkarni  provided an Accepted Solution to post by @KevinBradberry  Modification Uploaded (blue plus sign)-how to clear it
https://community.ptc.com/t5/Windchill/Modification-Uploaded-blue-plus-sign-how-to-clear-it/m-p/735023
15. Arbortext: In June, @rl_01  bumped up a thread Using HTTPS/SSL to connect to Arbortext Publishing Engine by @Tusken_Raider_422171
https://community.ptc.com/t5/Arbortext/Using-HTTPS-SSL-to-connect-to-Arbortext-Publishing-Engine/m-p/708018
16. Arbortext:  @EL_9959997  received some help from @GarethOakes   related to Error “All subprocesses are currently busy”
https://community.ptc.com/t5/Arbortext/Error-All-subprocesses-are-currently-busy-quot/m-p/732782
17. Windchill SSE:  @EP_9964574  revitalized the GIT Integration usage and overview
conversation started by @ASailer  Thank you, @bson21  @Ted_Lin  @sdas-4
https://community.ptc.com/t5/Windchill-Systems-Software/GIT-Integration-usage-and-overview/m-p/700393#M7397
18. Windchill SSE:  @Chittaranjan_11  asked about How to compute the count of Requirements having no Assigned User Set in a RQ Doc?
https://community.ptc.com/t5/Windchill-Systems-Software/How-to-compute-the-count-of-Requirements-having-no-Assigned-User/m-p/732723
19. Mathcad:  @Cornel    got some help from  @LucMeekes on Bod Plot: Mathcad 15 vs Mathcad 11
https://community.ptc.com/t5/PTC-Mathcad/Bode-Plot-Mathcad-15-vs-Mathcad-11/m-p/734615
20. Mathcad:  @SA_9950729  received an Accepted Solution from @ttokoro  for the topic Combo-box alternative methods of utilization
Thank you  @Fred_Kohlhepp  and @LucMeekes  for also participating in the conversation!
https://community.ptc.com/t5/PTC-Mathcad/Combo-box-alternative-methods-of-utilisation/m-p/733154#M196203
