Jaime_Lee
Community Manager
PTC Community Monthly Stand-Out November 2022
See the Top Community Engagers and the Top Noteworthy posts for the month of November.
Top November 2022 Community Engagers:
@Werner_E @TomU @VladimirN @MartinHanak  @ttokoro  @Cornel @tbraxton  @LucMeekes
@ValeryOchkov    @avillanueva    @CW_9181033   @EdvinTailwind @N.Barnes @Dale_Rosema
@Brndn4 @StephenW @BenLoosli  @HelesicPetr @rleir   @ptc-4937106   @evandenbrink   @FriedhelmK
@Marco_Tosin
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for November 2022!  See if your community username made this list!  Or, read more about a topic that interests you!
1.  Creo: @EdvinTailwind asked about Corner Chamfer Workflow.  Thank you @MartinHanak  @pausob  , @kdirth @BenLoosli and @tbraxton for contributing to the conversation!
2. Creo:  The topic Anysys Simulate for Study of bolt pretension was started by @PS_10114112
Great dialogue with @skunks and @Chris3
https://community.ptc.com/t5/Analysis/Ansys-Simulate-for-Study-of-bolt-pretension/m-p/840131#M10997
3.  Creo:  @DCG received an accepted solution from @tbraxton for the topic Rotate text around circle
Contributions by @kdirth @StephenW and @pausob
https://community.ptc.com/t5/3D-Part-Assembly-Design/rotate-text-around-circle/m-p/839118#M126592
4.  Creo:  @Patriot_1776 was asking for more advice on how to be more efficient in the realm of Drawing mark ups/ redlines  This doesn't seem to be resolved from a Creo standpoint but @Constantin seemed to have given the most satsifactory answer.  Thank you, @KenFarley @kdirth @TomU and @StephenW for contributing to the conversation!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Drawing-markups-redlines-using-AutoCAD/m-p/839177#M126605
5.  ThingWorx:  @pjbiocco received an accepted solution for the topic How to prevent Custom widget resizing from Mashup Builder from @VladimirRosu_116627
6.  ThingWorx: Another accepted solution was received by @VladimirRosu_116627 for the topic Working with JSON and Arrays started by  @jensc @VladimirN provided a helpful support article as well!
7.  ThingWorx: @gch asked about  Another accepted solution was received by @VladimirRosu_116627 for the topic IoT Hub Connector & Ports @pshashipreetham and @VladimirN also contributed to the conversation!
https://community.ptc.com/t5/ThingWorx-Developers/IoT-Hub-Connector-amp-Ports/m-p/833847#M60076
8.  ThingWorx: @wcui provided some great troubleshooting and advice for the question Run EMS as background job posted by @Vimal_Rawat.
https://community.ptc.com/t5/ThingWorx-Developers/Run-EMS-as-background-job/m-p/837893
9.  ThingWorx: @Rishabh345 asked a question about Unable to use JSON stringify0 on a JSON
Thank you @SachinSharma for contributing to the conversation!
https://community.ptc.com/t5/ThingWorx-Developers/Unable-to-use-JSON-stringify-on-a-JSON/m-p/839345
10.  Vuforia:  @AndreaT bumped up a topic posted in August from PTC Wayfinder Widget Open Beta!
with a follow up question. Great feedback from @AmberWright
https://community.ptc.com/t5/Vuforia-Studio/Wayfinder-Widget-Open-Beta/m-p/812159
11.  Vuforia:  @Pietro_Padovan received an accepted solution from @ClayHelberg
Thank you,  @RolandRaytchev for contributing as well!
12.  Vuforia:  @Aditya  received an accepted solution from @RolandRaytchev for the topic
  Displaying multiple 3D Images after a particular interval in Vuforia Studio
https://community.ptc.com/t5/Vuforia-Studio/Displaying-multiple-3D-Images-after-a-particular-interval-in/m-p/836317
13.  Vuforia:  @AlexK  posted the topic  Hide Tagalong Button of 3D Panel
thank you @ClayHelberg
for contributing to the conversation and @RolandRaytchev for the accepted solution..
14.  Windchill:  @Nicholas.G  posted the topic Published PDF  and received an accepted solution from    @Ajit_Kulkarni  Thank you @MikeLockwood @HJ1 @Marco_Tosin
15.  Windchill: @AG_10330040 asked about  want to move the data from one context to another context through Customization  Thank you  @Ajit_Kulkarni @BenLoosli @rleir and @bhushan.d for contributing to the conversation.
https://community.ptc.com/t5/Windchill/want-to-move-the-data-from-one-context-to-another-context/m-p/839479
16. Mathcad:  Lots of creativity being inspired by the topic started by @ValeryOchkov titled New Oval-an ellipse  @Werner_E  thank you for adding to the fun and entertainment of this post!
https://community.ptc.com/t5/Mathcad/New-oval-an-ellipse-ellipse/m-p/837864#M203694
17.  Mathcad:  @PEAH is getting help with his inquiry  Mathcad Prime 8 is very slow - Tips or tricks to increase speed?  from @Werner_E @VladimirN and @terryhendicott
18. Mathcad:  @JXBWk received an accepted solution from @AlanStevens for the topic ODE solve give very spiky response  Thank you @ValeryOchkov @Werner_E @prop_design and @LucMeekes
https://community.ptc.com/t5/Mathcad/ODE-solve-give-very-spiky-response/m-p/838231
19.  Windchill SSE (Integrity): @VladimirN sent @PM_10327162    a knowledge help article to help with Facing issue to Import Reqif
https://community.ptc.com/t5/Windchill-Systems-Software/Facing-issue-to-Import-Reqif/m-p/840081#M7806Facing issue to Import Reqif
20.  FlexPLM:@kkari got some great feedback from salder for the videos posted in the  Adobe Illustrator Plugin 2.x:  Update an existing design
https://community.ptc.com/t5/FlexPLM-Discussions-Tips/Adobe-Illustrator-Plugin-2-x-Colorway-Image-Pages-in-FlexPLM/m-p/838315
 @PM_10327162
