Emeritus
PTC Community Monthly Stand-Out August 2023
See the Top Community Engagers and the Top Noteworthy posts for the month of August.
Top August 2023 Community Engagers:
@HelesicPetr @Werner_E @MartinHanak @jbailey @StephenW @tbraxton @avillanueva @ttokoro @Velkumar @LucMeekes @Cornel @IbrahimTayyab @kdirth @Snowshoeman @BenLoosli @terryhendicott @Dale_Rosema @J_power @Pettersson
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for August 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: ELDAFRAWY  asked about Tracking-down a circular reference in Creo 4
 Solution was provided by
@Lars_F
 https://community.ptc.com/t5/3D-Part-Assembly-Design/Tracking-down-a-circular-reference-in-Creo-4/m-p/896788#M130852
2. Creo: DanielMarton @CR_9888056received an accepted solution from  for topic Search for EMPTY, but existing string parameter in Search Tool
 https://community.ptc.com/t5/3D-Part-Assembly-Design/Search-for-EMPTY-but-existing-string-parameter-in-Search-Tool/m-p/896865#M130860
3. Creo: Thank you @YaroslavSinfor providing an accepted solution for Manohar_0127 on this topic finding better way to find the coordinates values of the boundary box.
https://community.ptc.com/t5/3D-Part-Assembly-Design/finding-better-way-to-find-the-coordinates-values-of-the/m-p/897129#M130869
4. Creo: Pius needed help with this topic - automated scaling of text size for annotations and offered him an accepted solution.
 https://community.ptc.com/t5/3D-Part-Assembly-Design/automated-scaling-of-text-size-for-annotations/m-p/896243#M130824
5. Creo: A question about Show parent at top of flat repeat region (drawing bom table)
was posted by wcash and an Accepted Solution was provided by
 https://community.ptc.com/t5/3D-Part-Assembly-Design/Show-parent-at-top-of-flat-repeat-region-drawing-bom-table/m-p/897223#M130880
6. ThingWorx: Velkumar @Arun_C@TonyZhang gave an Accepted Solution to Michael_Dezet for the topic Simple loop with columns
 https://community.ptc.com/t5/ThingWorx-Developers/Simple-loop-with-columns/m-p/896849#M63546
7. ThingWorx: The topic Want to use Shankey Chart as widget in Thingworx Mashup builder
 posted by moresvishal received an accepted solution provided by Velkumar
 https://community.ptc.com/t5/ThingWorx-Developers/Want-to-use-Shankey-Chart-as-widget-in-Thingworx-Mashup-builder/m-p/894314#M63418
8. ThingWorx:  provided a speedy response and Accepted Solution to the inquiry by
Siddharth_Jhs about How to connect Oracle Data Warehouse from Thingworx Platform
 https://community.ptc.com/t5/ThingWorx-Developers/How-to-connect-Oracle-Data-Warehouse-from-Thingworx-Platform/m-p/895561#M63476
9. ThingWorx: golsen1 asked ApplicationKey SetExpirationDate service does not accept a DATETIME value and Velkumar provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/ApplicationKey-SetExpirationDate-service-does-not-accept-a/m-p/897524#M63570
10. Vuforia: Aditya1702 shared a post about Vuforia Studio - Checkbox Widget
Thank you sebben for providing an Accepted Solution!
 https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Studio-Checkbox-Widget/m-p/891979#M11911
11. Vuforia: Aditya1702 shared a post about Changing opacity in Vuforia Studio
Thank you aletenti2 for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Changing-opacity-in-Vuforia-Studio/td-p/890526
12. Vuforia: AlexK posted the topic Wayfinder Widget Colors and received an Accepted Solution from sgreywilson
13. Windchill: smcvr posted the topic Attachments Table and received an Accepted Solution by HelesicPetr
 https://community.ptc.com/t5/Windchill/Attachments-Table/m-p/898422#M74347
14. Windchill: K_Patil asked about: Cannot see complete value of Attribute on information page and HelesicPetr
provided the Accepted Solution.
 https://community.ptc.com/t5/Windchill/Cannot-see-complete-value-of-Attribute-on-information-page/m-p/896827#M74134
15. Windhill: FS_10272716 asked about Usage of remoteMethodServer.invoke and RemoteMethodServer.ServerFlag with an Acccepted Solution from HelesicPetr
 https://community.ptc.com/t5/Windchill/Usage-of-remoteMethodServer-invoke-and-RemoteMethodServer/m-p/897446#M74242
16. Windchill: MC_10611882 asked about Creo Drawing changes not saving after check-in
and jbailey provided an Accepted Solution!
 https://community.ptc.com/t5/Windchill/Creo-Drawing-changes-not-saving-after-check-in/m-p/892744#M73904
17. Mathcad: lvl107 needed help with Mathcad 15 , Symbolic Evaluate ?
and ttokoro provided the Accepted Solution!
 https://community.ptc.com/t5/Mathcad/Mathcad-15-Symbolic-Evaluate/m-p/897267#M208390
18. Mathcad: regcurry needed with Root function for series of variables in MATHCAD 15
and helped with an Accepted Solution.
 https://community.ptc.com/t5/Mathcad/Root-function-for-series-of-variables-in-MATHCAD-15/m-p/896726#M208340
19. Mathcad: JXBWk asked about the CFFT and a sanity check and  provided the Accepted Solution.
 https://community.ptc.com/t5/Mathcad/CFFT-and-a-sanity-check/m-p/896308#M208296
20. Mathcad: Cornel needed with How to plot arrow lines in 2D and 3D?
and ttokoro helped with an Accepted Solution.
 https://community.ptc.com/t5/Mathcad/How-to-plot-arrow-lines-in-2D-and-3D/m-p/896767#M208343
