Jaime_Lee
Community Manager
Noteworthy December 2020 Posts
December Community Posts
ENGAGE= KUDO, REPLY, or SOLVE!
  1.  Creo:  @MartinHanak provided an accepted solution for @JF_4905386 's issue Unattended install of ptc creo 7 with licensing server using SCCM to install
“Thanks, this steered me in the right direction and I was able to retrieve the xml files needed to do an silent install of the applications.”  Thank you  @dnordin and  @rreifsnyder  for also contributing to the thread!
https://community.ptc.com/t5/System-Administration/Unattended-install-of-ptc-creo-7-with-licensing-server-using/m-p/701430
  1.  Creo:  @TomU  found out how to Hide Sketch Entities Outside of Sketcher
https://community.ptc.com/t5/3D-Part-Assembly-Design/Hide-Sketch-Entities-Outside-of-Sketcher/m-p/702515
  1. Creo:  The working “copy name” mapkey!  posted started by @bp_01 in 2013 revitalized by  @MH_4565366  and  @DomenicLaritz in December.  “Wow great! I am impressed! This is what I meant. Thank you very much.”
https://community.ptc.com/t5/System-Administration/working-quot-copy-name-quot-mapkey/m-p/448286
Thank you @ptc-129614   @StevenDumon @StevenDumonfor contributing to the thread!
  1. ThingWorx:    @RM12 helped re-energize   the thread  How to set up and configure Schedulers started by  @mneumann  in 2018
https://community.ptc.com/t5/IoT-Tech-Tips/How-to-set-up-and-configure-Schedulers/m-p/537793
  1.  ThingWorx:   @otluk  started a conversation about  MQTT Thing - Unauthorized to set Password
Thank you,  @SachinSharma    for also contributing to the thread!
https://community.ptc.com/t5/ThingWorx-Developers/MQTT-Thing-Unauthorized-to-set-Password/m-p/703332
  1.  ThingWorx:  @mberber  started a topic about  Error Executing Event Handler on Subscription
https://community.ptc.com/t5/ThingWorx-Developers/Error-Executing-Event-Handler-on-Subscription/m-p/701517
  1. Vuforia:  @micah started the topic Sequence animations on hololens
" We were able to solve the issue….”  Related threads and eSupport Help article were shared to help troubleshoot !
https://community.ptc.com/t5/Vuforia-Studio/Sequence-animations-on-hololens/m-p/701157
  1.  Vuforia: @whity  received an Accepted Solution for his inquiry related to Transmit text from label with js
https://community.ptc.com/t5/Vuforia-Studio/Transmit-text-from-label-with-js/m-p/702599
9. Vuforia:   @BenAtLmco asked  Manipulating Scene to Add New AR Content
https://community.ptc.com/t5/Vuforia-Studio/Manipulating-Scene-to-Add-New-AR-Content/m-p/703566#M9102
10. Windchill:  @kwoodley @ScottMorris @MikeLockwood  @jvonzastrow1 are having a conversation about How to notify specific group of users when file is Revised
https://community.ptc.com/t5/Windchill/How-to-notify-specific-group-of-users-when-file-is-Revised/m-p/701089
11.  Windchill:    New member @avis called @mlockwood-2
“better than Batman! faster than the flash!” with his post about his First Time Windchill Installation   Thank you
@BenLoosli  also for contributing to the thread!
https://community.ptc.com/t5/Windchill/First-Time-Windchill-Installation/m-p/701590
12. Windchill:  @JV_8742917  received an Accepted Solution from @mockwood-2 for his question about  "link between WTPart and WTDoc for 15.000 files as "described by" relation out of a spreadsheet."
https://community.ptc.com/t5/Windchill/link-between-WTPart-and-WTDoc-for-15-000-files-as-quot-described/m-p/702276
13.  Windchill:  An Accepted Solution is found in the conversation  Make publish rules language independent    between   @AnderasFromm @MichaelChatel and @BjoernRueegg
https://community.ptc.com/t5/Windchill/Make-publish-rules-language-independend/m-p/703689
14.  Windchill:  2018 thread Windchill APIs getting started  with contributions by @shambhabi @Sri  @mastachef @joshbybee  @cyag-5  and @Pradeepa  received Top Views in December!
https://community.ptc.com/t5/Windchill/Windchill-APIs-getting-started/m-p/564881
15. Arbortext:   @ML_9713336  reactivated the 2013 thread Segment Violation Errors !   New answer needed. Thank you for participating in the conversation!  @rarmstrong @GarethOakes  @ptc-4447136   @ctant   @jmaynard @amodee
https://community.ptc.com/t5/Arbortext/Segment-Violation-Errors/m-p/103079
16.  Arbortext: An active thread   Figure numbers in my Appendix are wrong is being discussed by @ML_9713336  and  @rlaborde
https://community.ptc.com/t5/Arbortext-Tips/Figure-numbers-in-my-Appendix-are-wrong/m-p/698119
17. Arbortext:   @ptc-1178792   started a discussion about Licence Management
Thank you @GarethOakes   and @VladimirN   for your participation!
https://community.ptc.com/t5/Arbortext/Licence-Management/m-p/703511
18. Arbortext:  The topic  (–103): Cannot checkout an uncounted license within a Windows Terminal Services guest session  started  by @xhuang  with an Accepted Solution by  @JeffStevenson  made the top viewed threads for December!
https://community.ptc.com/t5/Arbortext/error-103-Cannot-checkout-an-uncounted-license-within-a-Windows/m-p/185015
19. Arbortext:  The topic  (–103): Cannot checkout an uncounted license within a Windows Terminal Services guest session  started  by @xhuang with an Accepted Solution by @JeffStevenson made the top viewed threads for December!
20. Windchill SSE:  The  2016 topicIn a computed field, how do I count the number of items where a pick list is unspecified?  was revitalized by @Chittaranjan_11   and more answers are needed!  Maybe @unknown  @DanR.  @mkiessling  @KaelLizak   previous contributors can help!
https://community.ptc.com/t5/Windchill-Systems-Software/In-a-computed-field-how-do-I-count-the-number-of-items-where-a/m-p/222963
21.  Mathcad:   @payman started a thread about finding number of maxima of a noisy signal with an Accepted Solution from @ttokoro   @ttokoro !
https://community.ptc.com/t5/PTC-Mathcad/finding-number-of-maxima-of-a-noisy-signal/m-p/702847
22.  Mathcad:   @ValeryOchkov started an engaging discussion titled Pendulum Math model
https://community.ptc.com/t5/PTC-Mathcad/Pendulum-Math-model/m-p/703824
23.  Mathcad:    @lvl107  started a lively discussion with @-MFra-  and  @Werner_E  about Inscribed circle and altitude of triangle ?
https://community.ptc.com/t5/PTC-Mathcad/Inscribed-circle-and-altitude-of-triangle/m-p/701039
24.  Mathcad: The 2016 post   How to convert XMCD file into MCDX format? created by @dkothia
  became active again last quarter by @ptc-4817179  @ptc-4817179  @LucMeekes @VladimirN
https://community.ptc.com/t5/PTC-Mathcad/How-to-convert-XMCD-file-into-MCDX-format/m-p/400986
 25.  Mathcad:  @ValeryOchkov  received help from @Werner_E  and @Fred_Kohlhepp    with his inquiry about Help please with ODE solution
https://community.ptc.com/t5/PTC-Mathcad/Help-please-with-ODE-solution/m-p/703103
