Emeritus
PTC Community Monthly Stand-Out April 2023
See the Top Community Engagers and the Top Noteworthy posts for the month of April..
Top April 2023 Community Engagers:
@Werner_E, @HelesicPetr, @avillanueva, @MartinHanak, @tbraxton, @terryhendicott, @jensc, @ValeryOchkov, @VladimirN, @Hariharasuthan, @LucMeekes, @StephenW, @ttokoro,
@Chris3, @CornelBejan, @jbailey, @Velkumar, @-MFra-, @BenLoosli, @kdirth, @kdirth
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for April 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: DH_10606961 asked about Surface Extrude Not Visible - CREO Parametric 7.0.4.0. Great contributions by @tbraxton , @BHOoi and @kdirth.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Surface-Extrude-Not-Visible-CREO-Parametric-7-0-4-0/m-p/870428#M128801
2. Creo:  RV_8071958 received an accepted solution from Dario73 for topic Cannot edit dimensions in sketcher any more. Thank you, @MartinHanak for contributing to the conversation!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Cannot-edit-dimensions-in-sketcher-any-more/m-p/870960
3. Creo: Thank you  for providing an accepted solution for TC_10043994 on this topic - How would it be possible to create a series of models for process drawings within CREO 8.0, Merge?
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-would-it-be-possible-to-create-a-series-of-models-for/m-p/871816
4. Creo: @AS_8634671 needed help with this topic - Singularity - and Chris3 offered him an accepted solution. Thank you, Bogdan_M also for your contribution!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Singularity/m-p/870563#M128804
5. Creo: A question about Bend back option not creating correct feature was posted by VV_10659302 and an Accepted Solution was provided by kdirth.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Bend-back-option-not-creating-correct-feature/m-p/870348#M128797
6. ThingWorx: Sathishkumar_C gave an Accepted Solution to VCortes2203 for the topic Timezone problem between postgres and thingworx.
https://community.ptc.com/t5/ThingWorx-Developers/Timezone-problem-between-postgres-and-thingworx/m-p/872220#M62152
7. ThingWorx: The topic how to create service using JavaScript code in particular Thing posted by
Hariharasuthan received an accepted solution provided by TravisPickett.
https://community.ptc.com/t5/ThingWorx-Developers/how-to-create-service-using-JavaScript-code-in-particular-Thing/m-p/871531#M62108
8. ThingWorx: bchaudhary provided a speedy response and Accepted Solution to the inquiry by
AM_10639709 about "Not able to install thingworx Flow getting gateway error"
https://community.ptc.com/t5/ThingWorx-Developers/Not-able-to-install-thingworx-Flow-getting-gateway-error/m-p/872571#M62193
9. ThingWorx: AM_10639709 asked Performance advisor dashboard is not showing properly it is not loading any data? and bchaudhary provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Performance-advisor-dashboard-is-not-showing-properly-it-is-not/m-p/872575#M62195
10. ThingWorx: Siddharth_Jhs posted the topic Thingworx custom HTTP integration connector code example and received an Accepted Solution from Velkumar.
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-custom-HTTP-integration-connector-code-example/m-p/871095#M62072
11. Vuforia: Pawel_D. shared a post about Vuforia View for other AR glasses/Unity + Vuforia Engine. Thank you  for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-View-for-other-AR-glasses-Unity-Vuforia-Engine/m-p/871611#M11643
12. Vuforia: JR_10180367 asked "Vuforia Studio keeps giving me "Uh oh publish failed" errors."
Thanks @VladimirN for contributing with the Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Studio-keeps-giving-me-quot-Uh-oh-publish-failed-quot/m-p/869668#M11634
13. Windchill: NP_10570407 posted the topic Extraction of Primary content and secondary content
 and received an Accepted Solution by @avillanueva.
https://community.ptc.com/t5/Windchill/Extraction-of-Primary-content-and-secondary-content/m-p/871979#M71505
14. Windchill: SC_8321054 asked about the Create customize search view and jbailey provided the Accepted Solution. Thank you HelesicPetr, and @SWeiler_9940261for your contributions as well.
https://community.ptc.com/t5/Windchill/Create-customize-search-view/m-p/871519#M71423
15. Windhill: asked about Multiple Promotion states with an Acccepted Solution from HelesicPetr.
https://community.ptc.com/t5/Windchill/Multiple-Promotion-states/m-p/871416#M71405
16. Windchill: SS_10574885 asked about Primary content source default value and Marco_Tosin provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Primary-content-source-default-value/m-p/871749#M71475
17. Windchill: nbojcetic asked a question about Publishing of Additional Files for specific CAD Document types only in Released State not working and jbailey delivered an Accepted Solution.
https://community.ptc.com/t5/Windchill/Publishing-of-Additional-Files-for-specific-CAD-Document-types/m-p/871091#M71373
18. Mathcad: xyz123 needed help with Find minima and maxima of a function and  CornelBejan provided the Accepted Solution!  Thank you, , Ackurdeeve,  ttokoro for also participating in the conversation!
https://community.ptc.com/t5/Mathcad/How-to-use-the-symbolic-engine-to-derive-an-equation/m-p/872523#M206479
19. Mathcad:  PD_10423696 needed with Solve block solves it, but variable is undefined and  helped with an Accepted Solution. Thank you TA_10206400
for participating as well!
https://community.ptc.com/t5/Mathcad/Solve-block-solves-it-but-variable-is-undefined/m-p/871275#M206376
20. Arbortext: Publishing to PDF Arbortext 8.1 was JS_1027's topic, which received an Accepted Solution from bfriesen.Thank you!
https://community.ptc.com/t5/Arbortext/Publishing-to-PDF-Arbortext-8-1/m-p/868663#M32858
