Creo Tips and Techniques Webcast Series (West)
Welcome to Creo Tips and Techniques Series
Main Presenters:  Ryan Butcher (Technical Specialist, Fellow) and Lino Tozzi (Technical Specialist, Fellow)
Below you will find all the related webcast recordings and recommended additional learning resources.
  Webcast Title Description Learn Online Classes/Resources 1 Learn Online Classes/Resources 2
1 Creo Multi-Body Design Creo Multi-Body Design Creo: Multibody Design Class Info
2 Creo and Augmented Reality Creo and Augmented Reality Augmented Reality Class Info
3 Creo:  Generative Design Automated geometry creation using design criteria Creo: Generative Design Class Info Creo Generative Design Tutorials
4 Creo:  Simulation Live Real time simulation during design Creo Simulation Live Class Info Creo Simulation Live Tutorials
5 Creo:  Flexible Modeling Direct modeling features to edit imported data Creo: Flexible Modeling Class Info Creo Flexible Modeling Tutorials
6 Ansys Simulation Ansys Simulation Ansys Simulation Class Info
7 Harness Design Used with cabling to create harness mfg drawings Cable Routing & Harness Class Info Cable Routing & Harness Class Info
8 Manufacturing Automation  Tools for mfg efficiencies Mfg Training  Class Info
9 Additive Manufacturing Design for 3D printing Additive Manufacturing Class Info
10 Advanced Assembly Advanced techniques for assemblies Creo Advanced Assembly Class Info
11 Behavioral Modeling Automated design intent Behavioral Modeling Class Info
12 Surfacing Tips & Techniques Core Surfacing-ISDX-Freestyle Surfacing Class Info ISDX Class Info
13 Creo Mechanism Dynamics Creo Motion analysis Creo:  Assembling with Kinematics Connections Class Info Creo:  Mechanism Design & Analysis Class Info
14 Mathcad Express Mathcad Express Mathcad Tutorials
15 Design Exploration & Intelligent Fastener (IFX) Explore multiple design concepts; automatic assembly of fasteners
Design Exploration Tutorials
Intelligent Fastener Tutorials
16 Tool Design/Mold Analysis Mold design and flow analysis
Mold Design Tutorials
17 High Speed Machining High Speed Machining
Axis High Speed Milling Info
18 Prismatic & Multi-Surface Milling Standard mfg in Creo
Creo: Introduction to Milling Class Info
Creo:  Introduction to Turning - COMING SOON
19 Creo Unite & Import Data Doctor MultiCAD design collaboration Creo Unite Technology Tutorials
20 Plastic Part Design Plastic Part Design
Plastic Part Design Overview
21 Large Assembly Management Top Down design
Creo: Using Assembly Skeletons for Top-Down Design Class Info
22 Creo Sheetmetal Design Creo Sheetmetal Design Creo Sheetmetal Class Info Creo Sheetmetal Tutorials
23 Reverse Engineering Use scan data to create new part designs
24 Advanced Modeling Techniques Techniques for Sketcher, Selection, Sweeps, Deformation, Blends
25 Creo Simulate Advanced Creo based Advanced Simulation Creo Simulate Advanced Tutorials
26 Creo Render Studio Photo render your models Creo Render Studio Tutorials
27 Creo Model Based Definition 3D drawings (model centric designs)
Creating Annotations using MBD
Modifying & Publishing Annotations using MBD
28 Creo Automation Creo based automation tools:  Macros, Programming, Options Modeler
Creo Automation Tutorials
29 Creo Manikin Ergonomic studies with manikins Creo Manikin Tutorials
30 Creo Schematics Routed Systems design for all types of schematics Creo Schematics Class Info Creo Schematics Tutorials
31 Creo View Interference Lightweight view of CAD designs Creo View Tutorials
32 Creo Clearance & Creepage Analysis Clearance and Creepage analysis for electrical designs
33 What's New in Creo 8 & 9 What's New in Creo 8 & 9 What's New in Creo 8 & 9 Tutorials What's New in Creo 8 & 9 Blog
34 ECAD/MCAD Collaboration MCAD designer and ECAD designer collaboration
Data Exchange Tutorials
35 PTC University PTC Creo training
36 Advanced Framework Extension Design of steel structures Advanced Framework Extension Tutorials Advanced Framework Ext Tutorial
37 Creo Flow Analysis Simerics based CFD Creo Flow Analysis Tutorials
38 Creo Ansys Simulation Full Ansys based solution embedded in Creo Creo Ansys Simulation Class Info Creo Ansys Simulation Tutorials
39 What's new in Creo 9 What's new in Creo 9 What's New in Creo 9
40 Piping Design 3D routing of piping design Piping Design Tutorial Get Started with Creo Parametric Piping
41 Creo Layout & 2D Sketching Axis concentric design layout in 2D
42 Progressive Die Design Design of sheetmetal stamped parts
About Progressive Die Design
43 Virtual Interconnect Libraries for schematic design
44 Design Automation for Creo Partner automation tools
CadActive
45 Creo Automation with Smart
Assembly
SIGMAXIM
46 DFMPro Design for mfg (Partner)
HCL DFMPro
47 Creo Option Modeler Design optionality in Creo Assemblies
Creo Options Modeler
48 What's New in Creo 10 What's New in Creo 10
What's New in Creo 10 Tutorials
49 Creo Ansys Simulation Full Ansys based solution embedded in Creo
50 Creo Composites Creo Composites
Creo Composite Tutorials
51 Creo:  Things You Might Know But Probably Don't Creo:  Things You Might Know But Probably Don;t
Creo Tutorials
52 Multi-Axis Milling with Creo NC Multi-Axis Milling with Creo NC
Intro to Milling
53 Creo Additive Manufacturing Creo Additive Manufacturing
Intro to Additive Manufacturing
54 Creo Patterns Creo Patterns
Creo Patterns Tutorials
55 Sketcher Sketcher
Sketcher Tutorials
56 Turning Turning
57 Creo 11 Creo 11
58 Resolving Geometry Issues
 Creo: Part Design Intent and
Reference Management
Training Session:
Creo: Assembly Design Intent and
59 Product Insights Product Insights
60 Solid Model Tools in Creo NC Solid Model Tools  in Creo NC
61 Rapid New Product Development Using Generative, Additive and Simulation Rapid New Product Development Using Generative, Additive and Simulation
62 Creo Class A Surfacing NEW SCHOOL Creo Surfacing with Bart Brejcha from Design Engine
63
Next Generation Model Based Definition Using
Creo + Windchill
Mark Nielsen (Principal of Tech Azul) What is MBD?
Training Session:
Creo Creating Annotations Using Model Based Definitions
Training Session:
Creo: Modifying and Publishing Annotations Using Model-Based Definition
64
Things I Love About Creo - Featuring Michael Bourque
General Tips on Numerous Topics to enhance your Creo experience
Creo Tutorials
65
Simplifying Models for Downstream Use
How To make Assembly Models more usable by people inside and outside of your organization by removing unnecessary small parts, internals components, or even sensitive data.
Learn Online Classes / Resources 1
Managing Large Assemblies LEARN Class
Learn Online Classes / Resources 2
Shrinkwrap Tutorials
Simplified Rep Tutorials
66
Creo Flow Analysis-What's Existing, What's New, Industry Specific Examples
(Creo Flow Analysis - What's Existing, What's New, Industry Specific Examples)
67
Creo Harness Manufacturing Extension Tips n' Techn... - PTC Community
Creo Harness Manufacturing Extension from PTC & Virtual Interconnect.
Tom Quaglia (Solution Consultant, Fellow), Kieran Gilhooley (Software Development Manager, Virtual Interconnect), Scott Ferguson (Project Development Manager, Virtual Interconnect)
Routed Systems Brochure with HMX Info
Creo: Creating Harnesses and
Routing Cables 2
Note:  Explore the Harness Manufacturing Extension (HMX topic is towards the end of this 3 hour class)
68
ModelCheck And Performance Advisor Tips and Tricks
Irena Roggeveen
Creo Product Manager
Adam Manfredonia
Creo Solutions
69
Creo Tips & Techniques (Simulation Updates)
PTC Creo Tips & Techniques (Simulation Updates in Creo 11, 12, 13) with Todd Kraft
70
Creo Parametric Wire Harness Design
Creo 12 Cable Harness Design T&T with Adam Manfredonia  PTC (Principal Applications Engineer Southern) California
71 Creo Engineering Notebook
Creo Engineering Notebook with  by Anji Seberino (SME Field Director -CAD Segment)
72 Creo Toolkit Applications for CAD Quality, Productivity, AI Readiness and Digital Thread
Creo Toolkit Applications for CAD Quality, Productivity, AI Readiness and Digital Thread by Anika Kapoor, Technical Manager at Kalypso
73 What’s New in Creo 12.0? Mark DeCraene, (PTC Principal Solutions Consultant)  shares highlights from the Creo 12.0 Update Session. New 12.0 Learning Connector Videos
73 Creo 13,4 What's New Tips & Techniques Session Creo 13 What’s new from PTC Application Engineers New Creo 13 Learning Connector Videos
74 Creo AI Tips + Techniques
Creo AI Tips + Techniques with
Lino Tozzi
Director, CAD Segment Hub
You may also find similar content in our East Coast Webcast Series.
Dayna,
Thanks for compiling all this wonderful content, you, Ryan, Lino, and the rest of the PTC team have done a great job on these. I hope to see this continue in the future.
Thank you!
