Emeritus
PTC Community Monthly Stand-Out March 2024
See the Top Community Engagers and the Top Noteworthy posts for the month of March.
Top March 2024 Community Engagers:
@Werner_E @HelesicPetr @MartinHanak @avillanueva @Velkumar @ttokoro @Cornel @StephenW @d_graham @LucMeekes @tbraxton @terryhendicott @BenLoosli @Perez @Aditya1702 @Marco_Tosin @Amirtharaj_K @Pratik_Aswale @Patriot_1776 @Hari_Vara
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for March 2024!  See if your community username made this list!  Or, read more about a topic that interests you!
1.  Creo: @AA_11007722 asked about Applying Filter-By Rule in Drawing-Tables. Great contributions by ,and
https://community.ptc.com/t5/3D-Part-Assembly-Design/Applying-Filter-By-Rule-in-Drawing-Tables/m-p/940221#M134129
2.  Creo: AS_11004841 received an accepted solution from @ysinitsyn for topic  how do I make inner acme/trapezoidal thread?  kdirth, @tbraxtonand thank you for participating in the conversation!
https://community.ptc.com/t5/3D-Part-Assembly-Design/how-do-I-make-inner-acme-trapezoidal-thread/m-p/939411#M134066
3. Creo:  An interesting conversation with @XDN  @StephenW and @KenFarley around Gear teeth and spline hub shaft
https://community.ptc.com/t5/3D-Part-Assembly-Design/gear-teeth-and-spline-hub-shaft/m-p/841577
4.  Creo: Chris3 needed help with MBD combo state start part recommendations  and received an accepted solution from llie
https://community.ptc.com/t5/3D-Part-Assembly-Design/MBD-combo-state-start-part-recommendations/m-p/938482#M134022
5.  Creo: A question about Sheet metal Forming was posted by AC_10274110 and an Accepted Solution was provided by !  Thank you for contributing to the conversation
https://community.ptc.com/t5/3D-Part-Assembly-Design/Sheet-metal-Forming/m-p/940146#M134123
6.  ThingWorx:  Sathishkumar_C gave an Accepted Solution to Jamal8548 for the topic The property VALUE of my thing just hides itself. DanZ thank you for your contribution!
https://community.ptc.com/t5/ThingWorx-Developers/The-property-VALUE-of-my-thing-just-hides-itself/m-p/941808#M66283
7.  ThingWorx: The topic Property values are repeating while using QueryPropertyHistory Service in ThingWorx was posted by Aditya1702 and an accepted solution provided by Velkumar. Thank you Rocko, H_1234 for contributing to the thread!
8.  ThingWorx: Sathishkumar_C provided a speedy response and Accepted Solution to the inquiry by Snoopy_hu   about How to add an image from a repository to a table?
https://community.ptc.com/t5/ThingWorx-Developers/How-to-add-an-image-from-a-repository-to-a-table/m-p/938425#M66040
9.  ThingWorx: Pratik2 needed help with How can I Fetch specific property data from QueryPropertyHistory and show in a line chart graph.Thank you Velkumar for providing an accepted solution!
@Velkumar
https://community.ptc.com/t5/ThingWorx-Developers/How-can-I-Fetch-specific-property-data-from-QueryPropertyHistory/m-p/940380#M66171
10.  ThingWorx: Snoopy_hu posted the topic rest API and received an Accepted Solution from Velkumar.
https://community.ptc.com/t5/ThingWorx-Developers/rest-API/m-p/940240#M66158
11.  Windchill: MC_6294097 posted the topic Windchill Save As with Creo files and received an Accepted Solution by RM_11009726.
12.  Windchill: RR_10661622 asked about document rename not updating in task headlines and received an Accepted Solution from  Thank you Sarathkumar_M for participating in the conversation.
https://community.ptc.com/t5/Windchill/document-rename-not-updating-in-task-headlines/m-p/938954#M79332
13.  Windhill: PB_11008310 asked about Creo View does not get launched from Windchill Standalone browser with an Acccepted Solution by
https://community.ptc.com/t5/Windchill/Creo-View-does-not-get-launched-from-Windchill-Standalone/m-p/940344#M79399
14.  Windchill: VG_WC12 asked about WTPart OIR doesn't work when auto-associate to EPMDocument and Hari_Vara provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/WTPart-OIR-doesn-t-work-when-auto-associate-to-EPMDocument/m-p/939348#M79357
15.  Windchill: ML_10905028 had an inquiry about After installation, unable to view or edit the lifecycle or workflow templates. Sarathkumar_M delivered an Accepted Solution. Thank you
@avillanueva
https://community.ptc.com/t5/Windchill/After-installation-unable-to-view-or-edit-the-lifecycle-or/m-p/938405#M79282
16.  Mathcad: Bogdan_d posted the topic Capacitor model unit issue and ttokoro provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Capacitor-model-unit-issue/m-p/937217#M210760
17.  Mathcad: AD_10780197 had a question about Planetary gear forces. ChrisKaswerthank your for the solution!https://community.ptc.com/t5/Mathcad/Planetary-gear-forces/m-p/939011#M210872
18.  Windchill SSE: AarushiS_0605 asked about OSLC Integration with IBM DNG using Windchill Modele
MangeshDevraj provided an Accepted Solution.
https://community.ptc.com/t5/Windchill-Systems-Software/OSLC-Integration-with-IBM-DNG-using-Windchill-Modeler/m-p/935253#M8017
19. Arbortext: JSkog asked about Eliminate an element used throughout document, but retain text it's wrapped in and ClayHelberg provided the Accepted Solution.
https://community.ptc.com/t5/Arbortext/Eliminate-an-element-used-throughout-document-but-retain-text-it/m-p/937035#M33114
20.  Arbortext: jsterlin posted the topic Macro for IsoDraw 7.3 - Position and insert a new text in a CGM. Thank you bfriesen for your input!
https://community.ptc.com/t5/Arbortext/Macro-for-IsoDraw-7-3-Position-and-insert-a-new-text-in-a-CGM/m-p/935505#M33096
